an idle observation...
Old Nov 2, 2009 | 09:12 PM
hogginit's Avatar
hogginit
Notice it on mine also. If you look at the front tire when doing this you can see that the tire is adding to the vibes.
Old Nov 2, 2009 | 09:33 PM
brettnbama's Avatar
brettnbama
mine vibrates with or without front brake. Its when you give it some throttle that it smooths out
Old Nov 2, 2009 | 09:51 PM
Gearhead3's Avatar
Gearhead3
Somone once suggested it was only on bkes with antilock brakes. Can anyone confirm?? Mine has ABS and does it.
Old Nov 2, 2009 | 10:12 PM
Da Butcher's Avatar
Da Butcher
Actually it's your brakes that are stopping the tire's slight back-and-forth rotation on the axle that is amplifying that which is already there that you are simply redirecting. The motor is not a balanced motor as we all know. Everything on the bike is absorbing that vibration to a degree relative to it's mass and location. With the motor kicking fore-and-aft, the forks are acting like a whip so-to-speak albeit with far less dramatic oscillations. Those oscillations essentially "roll" the tire back-and-forth on the tarmac a minute amount and when you apply the front brake, you reduced the front wheel's ability to absorb that portion of the vibration mentioned earlier. Hence the shaking when the front brakes are applied. The rear swingarm ("fork" as Harley likes to call it) is on nearly the same plane as the energy and will not transmit those oscillations like the front forks which are on a plane nearly perpendicular to the movement. Hope that helps.
Old Nov 2, 2009 | 10:55 PM
sanaga's Avatar
sanaga
my 07 ultra did it, teeth chattering, almost cant talk clearly...but my 09 sg now smooth as silk...vibrate still there but small vibe and no teeth chatering.....
Old Nov 3, 2009 | 08:34 AM
scatpac1's Avatar
scatpac1
Plus one, when you apply the brakes, now the energy of the vibrations is tied in with the rotors, through the pads, up the forks and so on.
Old Nov 3, 2009 | 08:45 AM
Jukebox's Avatar
Jukebox
Your kidding right? The 77'FXE i had would vibrate so bad the the even red locktite would not hold my tail light assy on. Was riding down the road one day,about 65mph and my whole assy. fell off from all the vibration that bike would make. I love it,that shows me how much power I have at my command while riding. The wife has a Heritage,I the RG,I would rather be on my than hers.JMHO
Old Nov 3, 2009 | 11:57 AM
MFA's Avatar
MFA
I have a theory on that causing the vibration change. When you press the brakes the brake lights come on which draws more current causing the alternator to work harder, which puts additional load on the engine. You can notice it in your car as well (just a slight decrease in rpm) when you turn on the head lights.
Old Nov 3, 2009 | 12:06 PM
BigGdawg's Avatar
BigGdawg
I never put both feet down and the back brake is on, not the front.
Old Nov 3, 2009 | 12:40 PM
MFA's Avatar
MFA
It does not matter which brake is pressed, the same lights come on.
