Does this weld look normal???
Old Nov 8, 2009 | 09:29 PM
krwould's Avatar
krwould
Originally Posted by BLKBAGGER
It look like the welder had a second thought and went back for another pass. Typical Harley weld.
Looks like one of my first welds I tried in welding school back in 1979!
Old Nov 9, 2009 | 05:28 AM
DrPlastic's Avatar
DrPlastic
Thats not a bad weld it is a "character" weld. It all adds to the aura and heritage of owning a Harley! LoL!
Old Nov 10, 2009 | 10:55 AM
DD4life's Avatar
DD4life
frame is not painted it is powder coated. different process.
did you buy it new?
Possibly that spot did not get completely cleaned before powder coating.
Or, a crack is developing now. I have seen a few cases where splatter beads
were on a weld from the factory, not common but does happen.
To be safe I would have it xrayed. some metal shops can do it.
At least, sharp knife cut around blister, flake it off, and visually inspect.
If under warranty let HD do it.
Old Nov 10, 2009 | 11:16 AM
autochek's Avatar
autochek
Heck man, that's not a weld it's a gussett.
Harley was making sure you got your money's worth.
Old Nov 10, 2009 | 11:27 AM
n8dc's Avatar
n8dc
You need to do a search and find the guy that had no weld I think it was and demanded a new bike?.. ... Was free entertainment.. Ive been welding on stuff for years and im here to tell ya it dont have to be pretty to work although for 20k it should be.. Im going for a ride here in a while ill have to look at mine when i get to the garage...
Old Nov 10, 2009 | 11:45 AM
07JakeelwoodHD's Avatar
07JakeelwoodHD
Someone posted a picture of a weld failure in that same location several months ago.dealer had to replace entire frame
Markymannn's Avatar
Markymannn
Originally Posted by n8dc
You need to do a search and find the guy that had no weld I think it was and demanded a new bike?.. ... Was free entertainment...
That's what I thought of. Here it is for your repeat entertainment
https://www.hdforums.com/forum/touri...09-flhtcu.html
Old Nov 10, 2009 | 11:55 AM
krwould's Avatar
krwould
It pays to look em over good! I have found cracks in my rigid by accident, barely see the crack just where the paint started cracking. Looking at that pic it looks like it had been cracked for a while by the corrosion around it.
Old Nov 10, 2009 | 11:59 AM
UltraTheo's Avatar
UltraTheo
Aren't the frames mechanically welded in jigs by robots? Thought I remembered that from one of the Factory Tours. Maybe not though by the looks of it.
rh8234's Avatar
rh8234
I just went and checked mine. ('04 Ultra). It does not look quite as bad as yours, but when I wiped my finger across it to clean off some of the dirt, I could definately feel lots of splatter around the weld.
