Blow by setups..... Pics please.
Old Nov 16, 2009 | 07:36 AM
maineultraclassic's Avatar
maineultraclassic
Not that much oil comes out to make that big of a mess. Every once in a while I just take a rag and wipe it clean.
Steve
Old Nov 16, 2009 | 08:54 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Thanks for the pics and feedback! As for the mess, the filter(if I go this route) is washable like the K&N air filters so if the blow by filter starts showing signs of saturation, easily remove it, clean and replace. The benefit of venting to atmosphere far outweigh the miniscual cleaning. Venting back to throttle body = bubble gum to motor.
Old Nov 17, 2009 | 05:28 PM
UltraKla$$ic
Well, I got around to doing my blow-by setup. I appreciate all the feedback and pics. I decided to go with something that wouldn't show unless you were looking for it but it still provides ease of maintenance, cleaning, and reinstalling. The maintenance on this setup is no more involved than cleaning the air filter. Matter of fact, it will get cleaned simultaneously for continuity. The end result will be a cleaner burn as the oil mist will be routed to atmosphere vs. straight down the throttle body where it can gum up the components and junk.
In keeping with the theme of my bike I used black and chrome hardware.
Pic 1 is the where it all started.
3/8' fuel line.........black of course.
Tools and parts used. I didn't use the small hose clamps as I didn't need them
Backside of the Right PowerPACC vent........illustrating the incognito clamp. That bump will face toward the motor out of sight.
Like this............this is how it will be displayed.
Easily slid into place making for easy access and cleanup
Different angle
Can't even see it!!
I think I see it back there somewhere.....LOL!!
DONE!! HOLLA!!
I see you hiding back there!!
Total cost of project including filter..................$10
Old Nov 17, 2009 | 05:51 PM
dawg's Avatar
dawg
Looks great Darren, didn't know a smartass could do such good work
Old Nov 17, 2009 | 05:58 PM
qtrracer's Avatar
qtrracer
Default Vac u pan
This is way I would do it if I was starting from scratch. Don't have pics but you run that hose that you were going to hook up to the filter but intsead run it to a one way valve that is welded into the header collector just after the merge at a 45 degree angle to the flow. Helps pull crankcase pressure out of the case to help seal the rings at higher rpms. Although I have never tried this on a dry sump style motor , others may comment on effectiveness on this application.
Old Nov 17, 2009 | 06:00 PM
UltraKla$$ic
Gee thanks............................................ .I think.
LOL!!!!
Old Nov 17, 2009 | 06:16 PM
Guntoter's Avatar
Guntoter
Personally, I would not re-route the crankcase vent to the atmosphere unless you are getting a lot of oil dripping or spraying from the air cleaner. The vacumn created by the intake helps evacuate the crankcase far better than just venting to the atmosphere. That little bit of oil that goes back into the intake won't hurt anything and may actually help by putting a little bit of oil back on the valve stem. If you are worried about the oil gumming up the intake (which usually is not a problem in most cases) then shoot a little carb spray in there occassionally. Just make sure you use plenty of rags or towels around the engine so the chemical does not eat away at the engine paint if some drips out.
The bikes I have seen with small filters on vent hoses tend to have oil dripping off of it and has an oily looking frame underneath if routed that way.
Old Nov 17, 2009 | 09:32 PM
beracing's Avatar
beracing
Let us know Darren! I know I've been getting some blow by too, but I think I may have overfilled the oil when I changed it before my ride this past weekend. Ugh.. my guess is that is what has created the noticable difference. Put over 1000 miles between Sat and Sun, so figured I would just change the oil again and recheck the levels...
I do like your set up though! Nice work!
Old Nov 18, 2009 | 07:19 AM
riteway's Avatar
riteway
UltraK....Nice work.Great pics!!!! Thanks R.W.
Old Dec 5, 2009 | 03:20 PM
maineultraclassic
Finally got a picture of behind my Doherty backing plate showing the vent hoses going to the "T" and the hose going between the cylinders.
Then in this picture you can kinda see the hose going behind the shifter linkage -
Then I have it zip tied to the frame under the primary.
Steve
