cluch spring queton
Old Nov 15, 2009 | 09:10 PM
davessworks's Avatar
davessworks
Default cluch spring queton
Dawg posted the following (thanks!)
Originally Posted by dawg
37951-98 Nothing
37871-98A Yellow dot
37807-03 CVO Yellow dot / Pink dot
37871-04 Yellow dot / Yellow Stripe
37882-06 Redish Brown Square / Yellow dot
SE 380 lbs
98 330 lbs
04 300 lbs
06 300 lbs
Year Models P/N
99 99 - * ALL 37871-98
01 01 - * ALL 37871-98A
03 ALL 37871-98A
04 ALL 37871-04
06 37882-06
My question is when I change my cams for SE255 and ditch the stock headpipes and a/c should I be planning on changing the clutch spring on my Ultra Limited.
The current part is the 37871-04 (according to the parts manual). I'm also a little unclear why the 103 and 96 (37882-06 have different part #s but in terms of lb ratings are both 300 lb (based on above).
Old Nov 16, 2009 | 09:23 AM
twincam47's Avatar
twincam47
PN# 37882-06 (117 Kg)
PN# 37871-04 (135 Kg)
PN# 37871-98A (145 Kg)
PN# 37807-03 (165 Kg)
PN# 37951-98 (175 Kg)
2009blackpearle
Engine Mechanical Topics
Mar 12, 2018 08:14 PM
Toe Knee
Sep 10, 2012 05:11 PM
Watchfuliz
Jul 12, 2012 07:48 PM
jpb
Feb 22, 2012 09:45 PM
patriotmc
Dec 23, 2009 06:32 PM
