is there any tell tale signs to know if there is for sure a cartridge in the left side? both sides feel the same, weigh about the same and the same amount of fluid came out of both sides.
If it is stock, it came with a catridge. Aside from taking it apart, you can't tell.
Originally Posted by bulldogmoe7
got another question. if my buddy still has them he took his forks off of his 2006 road king and replaced them with chrome front forks. will his 2006 non cartridge left fork fit on my 2005 EGC??
Yes. But if you do that you might as well take both of his 06 forks and use them.
thanks dawg
ok hard decision now. since i am taking my forks to an indy to change the fluid out, do i buy the '06 forks and have them switch them out so i have 2 conventional style forks.
they will need to pull the pistons out of my '05 and place them into the lower casing of the '06.
If it were me, I would go with the 06 forks if you have a chance to get them cheap from a bud. If both sides are conventional, it's a lot easier to do fluid changes and you should be able to change your fluid yourself next time, if it was the cartridge that was preventing your doing it this time.
