To Flush or not to Flush?
Old Nov 21, 2009 | 06:15 AM
riteway's Avatar
riteway
Originally Posted by Bonesbike1
The other 1,000,000 Harley owners don't flush their engines and don't have any problems.
Man its your money.You do with it what you want....I have never thought or heard of such a thing.When i change my oil it looks almost as good as new.If you decide to do this please tell us your thoughts... Pro-Con..
Old Nov 21, 2009 | 06:18 AM
Jinks's Avatar
Jinks
Originally Posted by fireaxxe
I feel totaly safe doing this to my own bike.
I feel totally safe with YOU doing that to YOUR bike also. Not a chance in the world of me or anyone else doing that to mine!
Old Nov 21, 2009 | 06:37 AM
robbie52's Avatar
robbie52
Waste of good oil and money. But if it makes you fell better do it.
Old Nov 21, 2009 | 06:49 AM
JustDave71's Avatar
JustDave71
Originally Posted by DrSmaggs
I don't do chemicals... but this oil change (15k) I left the filter off and let it idle until clean oil started to run out. It didn't take but a second or two and was easy and pain-free.
Isn't that exactly what the rogue choppers setup does?
I actually bought one of those pucks because I'm **** and so far it's been a messy pain in the ***.
now that I think about it...couldn't I just leave the filter off, put a funnel under the filter housing and wait til clean oil came out if I wanted to be ****?
seems that THOUSANDS of motors have been done the conventional way and run just fine for thousands and thousands of miles, no?
Old Nov 21, 2009 | 07:02 AM
Estil's Avatar
Estil
I'm sure if the MOCO thought it necessary to flush the engine, they would have it as part of their routine service schedule and would charge a hefty fee for the flush, and have a "special" flushing fluid designed "especially for Harleys". Evidently, HD doesn't see a need to flush either.
For me, no flush.
Old Nov 21, 2009 | 07:08 AM
meatball64's Avatar
meatball64
For me, no flush.
Lets not give MOCO any idea to add to their schedule.
Old Nov 21, 2009 | 08:42 AM
Faast Ed's Avatar
Faast Ed
It's a lil easier on my softail. With the filter ON the bike I pour a qt in the oil tank, then watch with a flashlight thru the filler hole for the black oil to turn clean. Then drain again. Softies don't hold a lot of oil to begin with, so I like to change most of it.
Old Nov 21, 2009 | 09:23 AM
harley-jones's Avatar
harley-jones
There are only a few things that I flush, and oil ain't one of them!
Old Nov 21, 2009 | 09:40 AM
troy.j's Avatar
troy.j
Maybe I would consider thinning the oil to flush a car that had been neglected for a few years. You know the old woman’s car from next door that hasn’t had an oil change for 10 years and moves once a week to go to church. If I changed the oil and it was black and thick/lumpy I would think about it, but never my Harley. Thinner oil means less lube, less pressure (it runs out of the bearings quicker) and moving parts get closer together. Just plain bad for an engine. The only question is, is it better that or the years of buildup left in the motor? I maintain my ride, no thinning the oil for me.
Old Nov 21, 2009 | 10:23 AM
fireaxxe's Avatar
fireaxxe
This is the worst way to attempt to flush you oil system the clean oil leaves the pan then enters the oil pump. it is then pressurized to 35psi it runs past the oil pressure sensor on the front side of the engine then goes directly to the oil filter. From there all vital engine parts are lubricated, if you run the engine with no filter the pressurized oil that is suppose to be going to the engine is not getting there.
