Project Black out ... so far so good
Old Nov 21, 2009 | 07:42 PM
SMSgt B's Avatar
SMSgt B
Default Project Black out ... Completed!!!!!
It's been a busy day so far and almost got all the chrome pieces off my ride. Only have a couple more parts to take off, then Monday morning it's off to get them powdercoated gloss black. This has been one hell of a learning session...thank God for a service manual. Anyway, here is some things I have discovered so far:
1. Have a service manual ... this is a must
2. Put plastic under the bike prior to starting ... just look at my floor now
3. Have a rubber mallet ... some of the covers are tough as hell of get off ... just play whack-a-mole
4. taking off the rear turn signal bar is a bitch if you dont take off the fender or rear tire.
5. Wash your bike prior to starting
6. Take notes, label things or put the bolts/screws back in where they go
7. You have to take off the front footboard bracket to get the primary cover off.
Anyway...here are some pics so far:
And here is the finished product.
Old Nov 21, 2009 | 08:36 PM
threeten's Avatar
threeten
Great post, thanks for the pictures. Looking forward to the "after" pictures.
This gives me a healthy respect for just how much work is involved.
Old Nov 21, 2009 | 08:48 PM
scarygt's Avatar
scarygt
What exhaust is that... it looks bad ***!
Thanks, Scary
Old Nov 21, 2009 | 08:50 PM
SMSgt B's Avatar
SMSgt B
Thanks, Scary
Paul Yaffe Phantom
Old Nov 21, 2009 | 08:55 PM
MassHD's Avatar
MassHD
On a scale from 1 to 10 how loud is that exhaust? I had TD Rineharts if that helps.
Old Nov 21, 2009 | 09:48 PM
SMSgt B's Avatar
SMSgt B
Between 6-9. 6 when idling and just laying back. 9 when you get on it. Extremely deep tone due to big diameter and no baffle.
Old Nov 21, 2009 | 09:55 PM
Screamin Steve's Avatar
Screamin Steve
Can't wait to see the bike finished. Great pics!
Old Nov 22, 2009 | 04:32 AM
leohd's Avatar
leohd
when you gonna take off the rest of the chrome and parts???
Old Nov 22, 2009 | 06:44 AM
SMSgt B's Avatar
SMSgt B
Got tired yesterday and my lighting sucks in the garage. Finish it up today, then count and wrap up all the parts. So far my time has been 4 hours Friday night, 6 hours Saturday and guess about 2 hours today. That is slow for some folks but 1. need to take beer breaks and stretch 2. I have never broke into an engine so reading, reading, reading. 3. Taking notes ... did I mention beer breaks.
Wife goes "I hope you know what you are doing and can get it back together." So do I because I have another project (inner fairing, bars, front end and lowering kit) right after this one ... tackling 1 at a time.
Old Nov 22, 2009 | 07:45 PM
SMSgt B's Avatar
SMSgt B
Finished up taking the rest off today and definitely learned some things today.
The rear cylinder is WAY more difficult to take a part. Due to the way the engine is mounted, the left side (shifter side) bolts are under the frame and no room to pull them out. Not sure if this was the correct way but here are the steps I had to take get it them out:
(Ensure the push rods are at the cam base (lowest part)...per the service manual)
1. Remove the rocker cover (6 bolts)
2. Remove the right side breather bolt and completely loosen the left side (frame is in the way to get it out)
3. Follow the pattern illustrated in the service manual to remove the 4 bolts holding the rocker plate. You will only be able to get the 2 on the right side out. (So now you have 3 bolts on the left side that needs to come out with the rockers)
4. Side the rocker assembly to the left so you can grab the push rods to remove them. This gives you more room to move the rocker assembly around.
5. While lifting out (like trying to take them out) the 3 bolts so they don't go back down, slide the rocker plate to the right side and tilt up as you come out. This allowed me to get out the rocker assembly with the 3 bolts still in.
6. Follow the pattern illustrated in the service manual to remove the 6 bolts holding the bottom rocker plate.
Hope this makes sense and helps out someone
