The problem with dyno tuning - smart tune rocks!!
so when you are done,collected enought data to now have all the areas calibrated to 14.6. you can go into the AFR or Lambda table and change the AFR settings to what you THINK will be optimal. so say @ WOT 100% kpa or map,you wanted 13.2 AFR you should be able to change it now and it would be that desired AFR. once the map has been calibrated.(ve's are set in the ve table) you should be able to change the AFR table to what you want. or at least this is the theory behind smart tune. same thing we do on a dyno.I have found the farther away from this targeted AFR you change it to your desired AFR the more room there is for error. this is why we as tuners like to tune the AFR table as close to desired as we can (or at least I do). then make small changes in the AFR table to tweak or establish what make the motor happy,and what makes the best power.
for this reason it is always best to have it tuned by a competent tuner. you really have no way of seeing what the changes did unless you have a way to measure the changes.
that said... if you can grasp the smart tune, it can be safer,better, have more power than just a canned map.
down side is you might have erroneous data from reversion,caused by exhaust,cams etc. if you are not familiar enough with good data to weed out the bad data,the tune could turn out worse than before you started.
But I am going to change the cams and give a local Indy I have heard good reviews a swing at the SEPST soon. I figure I can always go back to the PCV if unhappy or if it works out, have Jamie re-map the PCV to the wife's scoot.
I don't think a dyno can simulate the variables of real time riding. It was explained to me that the dyno is normally set at one pressure load for the tuning session, where as real time riding the pressure load varies, 2 up, single rider, uphill, downhill. As I stated before I'm not an expert, but I'm gaining experience.
also sounds like your tuner tuned wide open throttle and maybe Idle and that was it.
A dyno can create all the loads or conditions you will encounter,and even the ones you will never ride at. a proper dyno for tuning EFI has a eddy current brake or tq. arm. with a tuner that knows how to use these brakes,he will be able to hit hit every rpm/ MAP (KPA load vacume) throttle position,and do a complete tune.
1HarleyGuy1
