Bike Just quit running??
Old Nov 29, 2009 | 05:59 PM
hddan502's Avatar
hddan502
Take the gas cap off, then replace, try to start. Happen to a bud a while back, defective seal? He could only run a few yards. New gas cap, problem solved, in his case. I had never seen that happen before.
Old Nov 29, 2009 | 07:13 PM
2003Springer's Avatar
2003Springer
Sounds like he has a fuel prog. pump or filter!
Old Nov 29, 2009 | 07:24 PM
jbird79's Avatar
jbird79
I took off the cap, and turned the ign. on.. I can hear what sounds like fuel spay in the tank, but I dont see fuel spay.. I've taken the cap off, and replaced a few times.. But should I hear what sounds like fuel spraying in the tank?
Old Nov 29, 2009 | 07:45 PM
maineultraclassic's Avatar
maineultraclassic
Did you check for any blown fuses?
Anything else not working at all?
Steve
Old Nov 29, 2009 | 07:55 PM
jbird79's Avatar
jbird79
yep, checked all fuses.. everything else seems to be working
Old Nov 29, 2009 | 08:06 PM
roadgliderick's Avatar
roadgliderick
time for a new bike
Old Nov 29, 2009 | 08:16 PM
bdp's Avatar
bdp
I had a blown ignition fuse, the short was in the right grip about an inch down the wire from the run switch
https://www.hdforums.com/forum/touri...use-w-fix.html
Old Nov 29, 2009 | 08:35 PM
stro1965's Avatar
stro1965
Unhook that fuel line disconnect and see if there if fuel in the line under pressure. Mine was NOT and it turned out that the disconnect fitting itself was bad, couldn't get fuel. (of course, this could also mean fuel pump or a few other things too)
This happened to me at about 20,000 miles on my '07. One clue was when you would spin the chrome part that you lift to disconnect...it had a "catch" in it, wouldn't spin smoothly.
Old Nov 29, 2009 | 08:51 PM
cdestuck's Avatar
cdestuck
Could be a lot of things but the exact thing happened to my bike and it turned out that the fuel tube slipped off the fuel pump in the gas tank.
Old Nov 29, 2009 | 08:53 PM
Jim Gumbel's Avatar
Jim Gumbel
I have heard of this hose problem on 07 also. My brothers Fatboy had the same problem. They covered it under warranty. Good Luck.
