redshift 575 cams
Old Dec 3, 2009 | 01:38 PM
pmcburne's Avatar
pmcburne
Default redshift 575 cams
Question for anyone who has installed redshift 575 cams. Are these a bolt-in with no head-work? Also do they produce any valve-train clatter? They were recommended to me by Zippers as an alternative to the Andrews 54H.which I was originally considering. My bike is a 07 FLHR with D&D fatcat, tts, Big sucker A.C. and no headwork. Thanks.
Old Dec 3, 2009 | 01:48 PM
prodrag1320's Avatar
prodrag1320
nice cams,we`ve done a couple builds with them,great midrange,you`ll need springs and check valve to valve & valve to piston,but we`ve always been ok (but ALWAYS check)
kirby
facebook: kirby apathy
Old Dec 3, 2009 | 02:06 PM
FLHTCU Owner's Avatar
FLHTCU Owner
PM Dawg that is on the Forum here. I believe he has the Redshift 575 cams and could tell you how they are operating.
Old Dec 3, 2009 | 03:25 PM
UltraKla$$ic's Avatar
UltraKla$$ic
If I remember correctly Dawg kept his stock springs. He's a cheap bastage, so that may be the reason why.
LOL....j/k, I think the stock springs max out with .575 lifts.
Old Dec 3, 2009 | 04:14 PM
dawg's Avatar
dawg
I have the 575's. The stock springs will work just fine. You will need adjustable pushrods though and cannot use the stockers. I do not have any headwork done and it is considered a bolt in cam. I will be doing a 103 kit soon and Zippers indicates that if you go 103 with the 575's that you have to use dished pistons. They will also work with a 110 as well. The Zippers sleeper build uses 575's, wiseco reverse dome 9:1 pistons and no headwork. This is what my 103 will be as well. The only other thing that I have is the EVO 30 tooth that gives me more off the line.
Old Dec 3, 2009 | 04:20 PM
dawg's Avatar
dawg
Actually I built my cams with parts I stole from my mother's basement The stock springs actually will go as high as .600 lift, not that I would do it though.
Old Dec 3, 2009 | 04:43 PM
prodrag1320
stock springs will have the spring travel to coilbind,but not near enough seat pressure,defenatly not recomended for a .575 lift cam (can you say "valve float!!"
kirby
Detroit Iron
Fuel Moto / Jackpot Mufflers
Oct 10, 2019 06:19 PM
mrsnipy
Mar 8, 2019 10:45 AM
Mars47
May 24, 2015 11:19 AM
1fathog
Dec 13, 2011 11:16 AM
lewain
Nov 3, 2011 07:43 PM
