tssm modual?
Old Dec 8, 2009 | 08:38 PM
rexver's Avatar
rexver
6th Gear
Default tssm modual?
can anybody tell me if part number 68922-00a has the security feature in it ? looked at fuses and there is a fuse in the slot for security , but i didnt get fob when i bought bike .... thanks
Old Dec 8, 2009 | 09:04 PM
dawg's Avatar
dawg
68922-00A shows "Security System Module" Has since been superseded to -00D. If you PM me your VIN I can run it and see for sure if it has security. If it has security you can get fobs at a dealer.
Old Dec 8, 2009 | 10:48 PM
KY HDRider's Avatar
KY HDRider
It is a security system module part number. I had the same situation when I bought my bike I didn't know it had the security system. The TSSM was on bike, but I did not get any fobs.
After I found the part number was a security module, I bought a couple of fobs from the dealer.
Unlike newer model bikes, the older pushbutton fobs used on our bike can be married to the bike using the ignition switch and turn signals. The procedure is in the owners manual. No dealer labor required.
After you get the fobs, you can access the code entered as the manual over-ride to kill the security if it is On and you lose a fob. It is another procedure in the owners manual. You can also change the code to something you can recall after you get the fobs.
Good luck.
Old Dec 9, 2009 | 05:54 AM
broziff's Avatar
broziff
If there is a wire that plugs in to it for the antenna its a security module. The stocker does not have an extra plug in for the antenna.
Old Dec 9, 2009 | 07:15 AM
maineultraclassic's Avatar
maineultraclassic
You can get the fobs on Ebay for pretty cheap money compared to the local stealer.
It's a simply process that is in the owners manual on how to marry the fobs to the TSSM.
Steve
Buddy WMC
Apr 25, 2012 12:02 AM
hogster1961
Jan 11, 2012 08:30 AM
Hog Yild
Apr 23, 2010 04:18 PM
workformetoo
Apr 27, 2008 09:53 AM
customrider31
Sep 20, 2006 08:52 PM
