Wheel bearing question
Old Dec 11, 2009 | 05:33 PM
vickon's Avatar
vickon
Default Wheel bearing question
On earlier model StreetGlide/RoadGlide (2002-2007) wheels can the 1in. bearings be swapped for 25mm (2008) ABS bearings?
Thanks!!
Old Dec 11, 2009 | 05:58 PM
SE120RG's Avatar
SE120RG
Thanks!!
yes, new bearings will run you about $75
Old Dec 11, 2009 | 09:47 PM
vickon's Avatar
vickon
So they can just be pressed in? No mods to the hub or wheel needed?
I read somewhere the 25mm ABS bearings where supposedly thinner.
Thanks
Old Dec 11, 2009 | 09:53 PM
lnrider's Avatar
lnrider
you can use kit 41454-08A, for the front
and 41453-08b for the rear.
roll on
-L
Old Dec 11, 2009 | 09:56 PM
vickon's Avatar
vickon
In >> these part numbers for the ABS bearings?
Old Dec 11, 2009 | 10:05 PM
vickon's Avatar
vickon
Disregard, found them and yes they are for ABS scoots ...thank you for your help!!
Dguy
Oct 28, 2014 06:47 AM
badger3x
May 18, 2014 09:13 PM
Dyno Don
Wheels/Tires
Dec 22, 2013 11:21 PM
AndyinTally
Jan 28, 2013 10:52 AM
foush56
Wheels/Tires
Jun 30, 2010 03:12 PM
