Wow!!!!!!!
Old Dec 12, 2009 | 01:19 PM
Damascus's Avatar
Damascus
Welcome and congrats! I have a 2009 RK Police and it's awesome. You will appreciate that pumped motor. One thing to keep in mind is that if you go with a top case, you may have to add a spacer because of the speed openers on the police saddlebags. At least that is how is on my model.
Old Dec 12, 2009 | 01:22 PM
Strat HD's Avatar
Strat HD
Originally Posted by deezee
Throw a gear drive cam in it and ride the **** out of it.
I didnt want to spend the money on one at the time and 1999 RK blew up 400 miles from home on the 1st day of a long weekend trip to the mountains. Tensioner shredded and took out the oil pump, etc......
Congrats. Find out if anything has been done to the cam chain setup. 99 was first year for the twin cam. There was some cam chain issues.
Well......... You wanted the bad.
Old Dec 12, 2009 | 01:35 PM
bigskyhd's Avatar
bigskyhd
Sounds like a pretty dang good Christmas for YOU this year. And what did YOU get your WIFE-EE?? Better be something she really wanted to pay the debt!! Congrats.
Old Dec 12, 2009 | 01:56 PM
jamesw's Avatar
jamesw
There's a couple of bearing issues, depending on your engine manufacture date; and some other cam chest concerns.
1. The bolt used to attach the drive sprocket to the rear cam could loosen and cause the rotational force to shear the cast key of the sprocket, causing engine failure. The design was changed to the splined setup that's used now, as well as a bigger bolt. Mine never had an issue, but the condition does exist.
2. The bearing used in the cam support plate for both the front and the rear camshaft was originally a ball bearing. The rear bearing failed due to the extra loading and the design was changed to use a roller bearing for the rear only.
3. The inner cam bearing is an INA manufactured one, with rollers spaced apart by a steel stamped "cage". Many here (myself included) prefer the Torrington bearing that has more rollers without the steel spacing cage.
4. The cam chain tensioners are a wear item, and seem to wear inconsistently. I pulled mine at 38k, and they were worn, but still OK, others have had them disintegrate much earlier, and cause lots of engine damage by being ingested into the
A: oil pump and scarring the cam support plate with a resultant loss of oil pressure
B: cam bearings
C: crank bearings
These are the worst case scenarios, and many have had their bikes run long and trouble free.
I weighed the options, and decided a gear drive and all new bearings was the best route for me. You have to pull everything out anyway just to change the rear cam support plate bearing, and to me it made sense to get the biggest bang for the buck by doing all the cam chest work at one time.
YMMV. __________________
Old Dec 12, 2009 | 02:10 PM
shortride's Avatar
shortride
Welcome to the King Club.
Old Dec 12, 2009 | 02:12 PM
surfcitybum's Avatar
surfcitybum
Extra COOL wife (lucky for you). Welcome from usually sunny SoCal.
Old Dec 12, 2009 | 02:24 PM
CWDoc115's Avatar
CWDoc115
Great Christmas present! Welcome to the best seat in the house!
Now what are YOU going to give your wife for Christmas???
Old Dec 12, 2009 | 02:31 PM
1sweetglide08's Avatar
1sweetglide08
Congrats on your new ride and welcome to the forum.
Old Dec 12, 2009 | 02:37 PM
leohd's Avatar
leohd
plus 1 on the cam bearings dealer might be able to run the vin and see if they were changed if not change em soon...Congrats... you should buy the wife a set of gear drive cams for christmas
Old Dec 12, 2009 | 02:44 PM
Time2Cruise's Avatar
Time2Cruise
Too cool, congrats on the new ride and the way cool wife. Ride safe. X10 on the cam chain tensioners.
