PC5 VS. Fuelpak
Old Dec 14, 2009 | 03:27 PM
Damascus's Avatar
Damascus
Originally Posted by boogaloodude
Well I'll be real interested in hearing how all this works out for you. I've got basically the same setup, only on an 07 police RK (same slip on's, se air cleaner) Are you going to put it on a dyno after you get everything all up and working?
No. Not much into the dyno thing. A little more torque and/or horsepower here and there doesn't do much for me. More interested in a cooler running/longer lasting motor than anything else. Even with my sport bikes I never got them dynoed because I was more interested in smoothing out the power. I already knew they were insanely powerful.
I will definitely get back to you with my seat of the pants/heat/quality/etc impressions though.
MIKE722's Avatar
MIKE722
I just purchased an 09 like yours Damascus. Should be in the truck on it's way here. Talked to Fuel Moto as well and the only difference is that they quoted me the Jackpot Dynotuned Mufflers. I'm sure this has been discussed, but what does this do to factory warranty?
Old Dec 14, 2009 | 03:54 PM
Damascus's Avatar
Damascus
Oh, I just assume it nukes the factory warranty even if it technically shouldn't.
It's much easier to have that mindset if/when something does go wrong and you go to the dealer and he says it's your fault.
For instance, if your frame cracks, that shouldn't have anything to do with your non-Harley air filter, but according to many a sneaky dealer ... maybe it does.
Along those lines ... I wouldn't necessarily advertise to your dealer that you made these changes and/or you may want to put the bike back to stock before you bring it in for a regular service/recall/problem/etc.
Old Dec 14, 2009 | 04:35 PM
Guntoter's Avatar
Guntoter
I run the FuelPak on my 2007 Electra Glide and it has made it run much better, and a bit cooler, than stock. However, the only mods I have done is the SE air cleaner and V&H Fishtail slip ons with the quiet baffles. The FuelPak has the settings for this exact setup so it did fine.
I considered the Power Commander but since I have no intention of doing internal engine changes I felt it would be too much money, and trouble, to put out. The FuelPak was pretty easy for a near retard as myself to install.
smprfi0231
Sep 29, 2012 01:42 AM
TopKat
Jul 19, 2011 03:42 PM
jpowell490
Feb 23, 2008 05:07 PM
hd_sob
Aug 16, 2006 12:28 AM
XARAN
May 16, 2006 03:16 PM
