Mustang backrest stays put now!
Old Dec 14, 2009 | 02:33 PM
DougM's Avatar
DougM
Default Mustang backrest stays put now!
I've been frustrated with my Mustang rider's backrest for the past 2 months I've had it because it would always bottom out when ever I leaned against it. I called Mustang and they were very helpful (customer service-wise) and sent me another detent screw and a hat for extra measure. Still didn't work.
I ended up using painters tape to protect the chrome and drilled out the stock indentions on the Mustang post. I used a 1/8" drill bit in a drill press. I had to remove the pivoting part of the post (the part with the pad attached) in order to get the indention post to lay flat on the drill press.
I ended up removing the seat by sliding up and over the indention post. Then I reset the detent screw to the correct hole to adjust the height. I put the seat back on by sliding it over the indention post and then reattached the pivoting part of the post with pad (by using the two button head allen bolts with locktite).
Now it works the way I wanted it to! It doesn't move down anymore when I lay on it. As an added benefit it doesn't come out anymore. That should deter theft. This mod isn't for anybody that likes to remove the backrest often or needs to take the seat off frequently. When I need to remove the seat I'll have to remove the pivoting part of the post in order to slide the seat over the indention post. That's a small price to pay to have a comfortable backrest that stays put!
Old Dec 14, 2009 | 02:42 PM
nvsteve's Avatar
nvsteve
Interesting fix. Thanks.
I adjusted my screw and it holds pretty good but not perfect.
MikeEyre74
Dec 28, 2018 08:30 PM
Gerald Fall
Jul 26, 2017 04:00 PM
dontdropit
Aug 27, 2014 05:11 PM
steelerdude1
Sep 20, 2012 10:15 PM
OldBoldPilot
Oct 14, 2010 05:25 AM
