Ceramic coating exhaust
Old Dec 17, 2009 | 06:37 AM
carlgrover's Avatar
carlgrover
Originally Posted by Twinrider
From what I've read, most of the guys doing it have old chrome or mild steel pipes that are discolored/rusting and it's just done to make them look better. I wouldn't expect a big difference in heat.
Yup. I had some new pipes for my ironhead ceramic coated in an effort to keep the bluing to a minimum. No difference in heat either. They still turn color also.
Old Dec 17, 2009 | 10:33 AM
The Road Warrior's Avatar
The Road Warrior
6th Gear
Check out this site.They can coat your pipes and create a design on the shields.Click on tattoo. http://cradin.com
Old Dec 17, 2009 | 03:25 PM
jag1886's Avatar
jag1886
I'm not doing it for looks the idea is to keep the heat in the pipe where it's suppose to be, it's a proven fact that ceramic coated headers run cooler and that you make more HP because hotter exhaust in the pipe flows faster.
I'm just asking if you need to coat both the inside and the outside, anyone know??
Old Dec 17, 2009 | 04:19 PM
blown alcohol's Avatar
blown alcohol
I had http://www.calicocoatings.com/ do mine 2-1 e-series pipe couple years ago. They used a different coating on the inside to aid exhaust gases to escape. The outside coating was called coolchrome. They do a lot of round track stuff, and their prices were reasonable.
Old Dec 17, 2009 | 05:26 PM
Scooter308's Avatar
Scooter308
Mine are Jet-Hot Coated, inside and out.
Had it done on my Nova Also.
http://www.jet-hot.com/
Old Dec 17, 2009 | 10:34 PM
Da Butcher's Avatar
Da Butcher
+1 on that Fact. Had ceramics on my small block after a few other sets and the difference was big in terms of ambient heat and was great when you were doing work on the motor because in no time at all the pipes were cool enough to grab.
Though this Post happens to be a bit early for me, I'm having my pipes, shields, and mufflers done soon, so I'll be posting some results once I get them back and installed on the bike. I'm going for a change in looks for the theme of the bike and for the reduction in temps. Though the results won't be anything like half the temps, there will be a positive difference and I'll accept all I can get. Promise to post when I get them on.
Old Dec 18, 2009 | 12:30 AM
hog-doc's Avatar
hog-doc
+1 on doing inside and out. When I was in Colorado we used Jet Hot they coated both.
jag, who in Boise is doing it? Iam in Meridain.
Old Dec 18, 2009 | 05:34 PM
jag1886's Avatar
jag1886
The name of the place is PRIMO and he's in Meridian, I called Donnie on the phone the other day and he sounds like a nice guy.
I'm pulling my pipes this weekend because my friend is having a set of cams put in his bike and is going to have his exhaust off this coming week, seo we are both taking our pipes in to have them done, Donnie only does the outside, that's all he can do with his equipment, he quoted me $75 to do the job and that includes blasting the pipes to get them clean and baking them after they are done and he uses the black finish.
Donnie does ceramic in batches and he's doing a batch next week.
Old Dec 18, 2009 | 06:32 PM
ranman469's Avatar
ranman469
from jet hot on heat reduction http://www.jet-hot.com/techinfo.html
next on my list
Old Dec 18, 2009 | 06:49 PM
shortride's Avatar
shortride
I had a set of truck headers Ceramic coated, and yes the inside gets coated as well. At least that what they did at Jet Hot Ceramic Coating.
