Cruise control
Old Jul 17, 2006 | 04:46 AM
Devil Dog's Avatar
Devil Dog
Default Cruise control
Well, I did it! I installed the cruise control today. Well, me and Mama. It went pretty well except for some minor glitches. I had trouble with the reinstallation of the ignition switch. And I don't have any brake lights. Neither the rear pedal or the front hand grips will activate the brake lamp. I checked the fuse. It was good. I hear a clicking sound in the "brake relay" in the fuse block. It might be toast. Anyway, I sure like the cruise. I took it out for a spin tonight to test it. ( I used hand signals, of course). It helped to buy a shop manual before attempting the install. Now I will work on the brake lamp problem. I wonder if I pinched a wire..................
Old Jul 17, 2006 | 09:17 AM
harley0711's Avatar
harley0711
Default RE: Cruise control
did you follow the instructions and put the spacer in the brake lever housing???? very important step -
Old Jul 17, 2006 | 10:00 AM
MOking's Avatar
MOking
I experienced intermitent cruise control for the first time over the weekend. If I had to guess, my stealer has a pinched wire from when they installed my chrome switch housings. I think it is in the switch for resume/excell.
The bummer is, it didn't work properly for two days while travelling out and one full day out of town. On the return home yesterday, it worked perfectly.
How is the stealer to find a problem that isn't acting up?
Old Jul 17, 2006 | 12:45 PM
ricoman's Avatar
ricoman
Seems like it's very easy to pinch a wire in the right side housing.
Are you certain the brake light isn't on all the time and that's why you don't see any change when you apply the pedal or lever?
There is an annoying little shim in the front switch housing. If it's lost the brake switch is on. Had to make a new one out of a thin piece of plastic (less than credit card thick).
All you can do is try until you get it, some vocabulary issues will come up, for sure!
Old Jul 17, 2006 | 02:39 PM
Domestic Violence's Avatar
Domestic Violence
quick release windshield and cruise control is what made me go with the RKC over the SG
cruise is awesome
Old Jul 17, 2006 | 03:52 PM
ZookHD's Avatar
ZookHD
Pull off the switchhousing. You may have pinched more than just one wire. If your foot brake doesnt activate your light, its definately electrical.
Old Jul 17, 2006 | 04:45 PM
jackj's Avatar
jackj
just for info, I had problems at one time with mine, HD dealer really could never find the problem, untilllllllllllllllllll, we disconnected the battery for some other work, and guess what, the control worked fine since, the control is really nothing more than a computor and sometimes you confuse them, disconnecting the battery for a few mins. permits them to reboot.
Old Jul 18, 2006 | 01:45 AM
Devil Dog's Avatar
Devil Dog
Well, the brake lamp worked on and off today. I took the bulb out, looked at it. Checked all the connections in the tail lamp assembly. Checked the fuse, the brake relay gizmo in the fuse block. Everything looked in order. Put it back together, had a smoke just staring at it and tried it again. It worked! I don't know what the problem was / is. It is still working. Just went and checked it. By the way, the cruise worked great today. It worked so well, I did not even notice it was 113 degrees while I was riding!
Sasquatch_VNV
Jan 18, 2019 08:46 AM
sh4325
Oct 19, 2015 09:34 PM
S&RSGLIDE07
May 1, 2013 09:30 PM
slhanks4
Oct 19, 2011 09:44 AM
deermasher
Jul 10, 2011 11:21 AM
