05 ultra cruise trouble
Old Jul 9, 2011 | 11:32 AM
deermasher's Avatar
deermasher
Default 05 ultra cruise trouble
well here's my problem and i think i know the answer but really not sure. i have a 05 ultra and the cruise will not disengage with the rear brake pedal, i also have no brake lights with the pedal pushed. now i'm thinking rear brake light switch. now here's the part that's throwing me i pulled the wire off the switch and it ohm'd out like it's working. so if the switch is bad why would it ohm out ok?
i did check the trouble code for the cruise and i got a 122 and that is for the brakes. the front lever will disengage the cruise and work the brake lights.
i stopped and picked up a new switch and i'm going to put it in but just not sure if it's my problem
Old Jul 9, 2011 | 12:48 PM
deermasher's Avatar
deermasher
changed out the switch and after getting line bleed off i now have brake lights again...still no idea why the one in there ohm'd out as if it was good?
Old Jul 9, 2011 | 08:33 PM
maineultraclassic's Avatar
maineultraclassic
So is the cruise working correctly now too?
Steve
Old Jul 10, 2011 | 09:04 AM
deermasher's Avatar
deermasher
yes it's now working too. I was in Delaware when I discovered it wasn't working. tapped the back brake and it wouldn't disengage. finished my ride up to Maine then back to home with no other problems
Old Jul 10, 2011 | 09:30 AM
shortride's Avatar
shortride
I've recently discovered the same thing on my '09. I haven't got the rear brake light switch replaced yet. Got to save an extra $85 for the labor.
Old Jul 10, 2011 | 11:21 AM
deermasher's Avatar
deermasher
the switch costed me $20.70 from a dealer and only took about a hour to put on and bleed brakes off. i know it could be done a lot faster but it was my 1st time and i do work slow. what i can't figure out is why the one that was in there ohm out like it was working when it wasn't
Sasquatch_VNV
Jan 18, 2019 08:46 AM
elPrez
Electrical/Lighting/Alarm
Jun 4, 2018 06:59 AM
jguilletjr
Sep 3, 2017 03:25 PM
Lantern
Jul 24, 2014 07:33 AM
masterblaster
Jul 3, 2011 02:59 PM
