Cam Project Day 3
Here is a thread where you can read feedback on this tool. Keep in mind that he sells three separate tools: Evo (3/4" bearing), early TC (7/8" bearing), and later-model TC's (1" bearing). You may need to register with HTT before being able to read the thread.
Labeling parts can't be over-stressed. Aric used plastic bags to keep things organized, and I used a folding table and placed a label (masking tape) next to each part in the order it was removed.
It can't be stressed too much that proper re-assembly of the oil pump and install of o-rings (including the two in the cam plate) is vitally important. If you pinch one or let one fall out during assembly you will be looking at problems later on, like sumping that will mean another disassembly to fix.
Some just buy the spacer kit for <$10 and have it ready just in case, so they don't have to make a trip to the dealer in the middle of the job. I rolled the dice and was lucky that I didn't need another spacer.
Again, great job. This should give confidence to even more people to do their own cam jobs.
Anyone have one of those?
iClick, you are right. The manual does state to use motor oil and makes no mention of assembly lube. The lubrication qualities of assembly lube, IMO, gives all parts an extra slick coating that sticks to all metal parts. I coated the entire cam, cam plate bores, inner bearings, sprockets, chains, and tensioners with oil first and then a good coat of lube. It's good insurance. I highly recommend the assembly lube - and it is cheap.
Red Loctite is specified in the "08 Touring Manual for the cam and crank sprocket bolts. I used blue loctite on everything else.
When using Gary Beatty's tool I recommend oiling all the tool threads before extracting the bearing. It makes turning the big 3/4 inch nut easier and probably reduces the risk of metal shavings from the threads.
The job can be done without the locking tool, but for $22 I think it makes the job easier if you are working solo.
When I wrap the project up I will try and put everything into one thread. I will also list the parts I used, and list the must have tools.
As I mentioned, I am not a mechanic, but if you are on the fence, I do have some good commentary to help you decide if you want to do this project. I will post that in my final thread as well.
Merry Christmas everyone!
A
