Oil change question
Old Jan 5, 2010 | 07:15 AM
fgunnr's Avatar
fgunnr
Default Oil change question
I have a 2009 Road Glide, 103ci Stage II big bore that I use synthetic oil in the engine, primary and transmission. I change all of the oil every January but due to health reasons I put less than 1000 miles on the bike in 2009.
Can I wait a while or should I stick to my annual change?
thanks
Old Jan 5, 2010 | 07:16 AM
UltraTheo's Avatar
UltraTheo
Probably still due the change. Hope your health is better this year and you can make up for last year! Ride safe.
Old Jan 5, 2010 | 07:26 AM
Jags93's Avatar
Jags93
I'd continue that routine. You may get water due to condensation that is not boiling out due to limited run time.
Old Jan 5, 2010 | 08:33 AM
dawg's Avatar
dawg
You didn't say where you are located and if you ride year round or not. You also didn't state how many miles a year you average (If you average more than 5k I would be changing some fluids prior to every January). Hope you are healthier this year.
Old Jan 5, 2010 | 08:36 AM
bfrank's Avatar
bfrank
I'd change it.
Old Jan 5, 2010 | 10:41 AM
gmc's Avatar
gmc
I doubt that you need to change it, just don't start your engine in the cold and let it idle or it can draw in moisture. I don't see how 1k miles is going to contaminate any oil, let alone syn. We waste alot of oil in this country. I know it's cheap compared to an engine but if your really worried you can get it tested. HD recommends 5k on their blend syn and even reg oil and they don't mention any thing about winter lay up.
Hope your better for 2010 season.
Old Jan 5, 2010 | 10:57 AM
RickDeVon's Avatar
RickDeVon
Changed mine @ 1000 with Amsoil 20/50 oil 10/40 Pri 75/140 Trans.Then @5000 @ 10k and now only every 10k..I ride year round
Jamus 76
Mar 24, 2019 01:19 PM
hd4evr2008
Oil Archive (no new posts)
25
Nov 19, 2018 08:47 AM
brihvac
Nov 12, 2017 01:25 PM
hd4evr2008
Aug 13, 2013 10:18 PM
troop
Jun 30, 2011 06:06 PM
