Jacket size
Old Jan 6, 2010 | 02:36 PM
08bluepearl's Avatar
08bluepearl
Default Jacket size
This may seem odd but, does your leather fit snug or loose? The large FXRG is snug around the shoulder. The sleeves and waist was fine. The extra large is loose around the waist, but fine at the shoulder, and okay at the sleeves. Just looking for some feedback before the purchase.
Old Jan 6, 2010 | 02:43 PM
rocstar50's Avatar
rocstar50
I prefer the snug fit especially if wearing jacket with protection fitted. I was advised by a retailer that the less movement the better if ever you have to depend on the elbow and shoulder protection. Never actually tried it out though !!
Old Jan 6, 2010 | 02:56 PM
RockerMike's Avatar
RockerMike
Mine used to be fairly loose, but now is a little tight. Maybe it shrunk.
Old Jan 6, 2010 | 03:08 PM
dhincc's Avatar
dhincc
Loose, but I wanted it that way. More room for air movement underneath, and for clothes and such in cold weather.
Ride safe!
Old Jan 6, 2010 | 03:49 PM
todd-67's Avatar
todd-67
I agree with the rational that tight is better if fitted with protective armor. My sport bike jackets were very tight...... to the point of requiring break in. My Cruiser attire is different. Like the above poster mentioned I want to be able to get air movement through it when I am on trips.
Old Jan 6, 2010 | 03:50 PM
bigskyhd's Avatar
bigskyhd
Leathers should fit good and snug. They're made that way by design. Too much room or movement is not what you want, unless you're specifically buying it to use in significantly cold weather and you're going to layer up to keep warm.
Old Jan 6, 2010 | 04:08 PM
petemac's Avatar
petemac
My 3 season leather jacket I like a little big so I can get a sweatshirt under it. My perforated leather jacket I wear when it's hot is tight sinceI only wear a tee shirt under it.
Old Jan 6, 2010 | 05:01 PM
piasspj's Avatar
piasspj
Mine gets almost snug with my arms out in front but a little loose with my arms at my sides. You might want to try on a few jackets of each size (see if the fit varies), also a different style may fit you better.
Old Jan 6, 2010 | 06:03 PM
Harleypingman's Avatar
Harleypingman
I have the FXRG in size large and works great with the liner removed; a bit too tight with the liner in the jacket. I've had the liner out of the jacket for two years and haven't misse it. I keep the liner in a saddebag and put it on when I take the leather jacket off when out and about.
Old Jan 6, 2010 | 06:08 PM
atrain68's Avatar
atrain68
Snug, but not so tight you can't wear the liner or sweatshirt. I think this gives protection and the back won't balloon up on the highway.
