Front Brake switch
Old Jan 9, 2010 | 02:39 PM
mtclassic's Avatar
mtclassic
Originally Posted by gja
Problem is I have all the fairing (including ignition) off the bike so I can't check if brake light stays on.
Is there anything that sticks out beyond the rubber boot? Looking in at the boot and lever, the boot will expand when pulling in the brake lever. I'm hoping this is a good sign.
As for experience, yup won't forget that again
just put the ignition switch back on to check. it takes a second to put it off and on. When I have to remove mine i always put the ignition switch back on so I can move the bars around and so I don't have to disconnect the battery.
Old Jan 9, 2010 | 03:06 PM
rbabos's Avatar
rbabos
Welcome to the ( forgot to put the shim in club).
Ron
Old Feb 6, 2010 | 11:33 AM
gja's Avatar
gja
Yup, it's official.....I've joined the broken switch club . Got the inner back on today, connected everything else and sho'nuf brake light stays on.
With this being said, what does it take to repair this debacle? Is it a matter of screwing in a new plunger, soldering new wire end on? Need some help here fellas.
Old Feb 6, 2010 | 11:38 AM
dawg's Avatar
dawg
It takes a $50 new switch and follow the manual.
Old Feb 6, 2010 | 05:45 PM
TexasBowhunter's Avatar
TexasBowhunter
FFT
I have done this with great success
Instead of replacing the switch assy go to the Hardware store and get a 1/4 long small dia. allen screw...No head just the allen wrench portion and screw the allen screw into the boot assy...the allen will contact the remainder of the plunger while protruding from the boot assy and your problems will be fixed for the price of a allen screw...
paul
Old Feb 6, 2010 | 06:16 PM
Dionicio's Avatar
Dionicio
Originally Posted by TexasBowhunter
FFT
paul
Your talking about a set screw. Good idea!, and definitly worth a try.
Old Feb 6, 2010 | 06:41 PM
fairplay's Avatar
fairplay
welcome to the "man, am I a dumba$$" club. There will be many events to follow. Remember, you still got away a lot cheaper than paying the dealer to do it.
Old Feb 6, 2010 | 08:11 PM
bagman1's Avatar
bagman1
recalled my post
Old Feb 7, 2010 | 08:44 AM
gja's Avatar
gja
FFT
paul
Went to Home Depot yesterday and got a set screw, figured what do I have to lose. Working like a charm now.
Thanks TBH!!
Old Feb 7, 2010 | 09:40 AM
TexasBowhunter
Set Screw
Yes thats what I was looking for earlier...Old Timers kicking in again...
The procedure worked for me a couple years or so ago and glad it worked again for someone else...
Glad to be of help
I would venture to say that even if you have another Brain fart you'll find that the switch will stand up to alot more then it previously did...
