Touring Bike Wobble
I was going to put another device on my bike called a "Stiffey" which goes on the outside of the swingarm bushings to help firm it up. I figured between the Progressive brace and this I'd be golden. But then I put the Ohlins shocks on and it took care of it so no need for a third fix.
A new and better quality front motor mount might be a good mod as well if the bike has 25k or more miles on it. There are some very good one's available and Sta-bo has one of them.
Who did you go through to get the Ohlins? I have had Ohlins on some of my off road race bikes, and I know what they do for them. Good stuff.
I'm no expert though and I would like to hear more about this from someone more knowledgeable than me for sure!!
The "Stiffey's" didn't look offset to me so my guess is they just fit in and do a mediocre job of firming up the back end. Again; I'm just assuming.
I've had to send the Ohlins back to get re-worked so at this moment in time I can not endorse them. I hope to in a week or two. I'm using this time to rebuild my forks and old air shocks. Who knows ... Maybe they will be better than the Ohlins. I won't know for sure until I can get the Ohlin shocks back and hopefully dialed in right this time. It's turning into a long and arduous ordeal at this point. I'm trying to be patient even though it isn't easy when it takes a week to send them out (with me having to pay the postage) and a week to get them back and that's not including all the time it will take to figure out what is wrong with them. I'm going on 2 months right now with this one product. While it has backed me into a corner time-wise; I think it will work out well in the long run. At least I hope so.
If you are interested in the Ohlins shocks the only shop I know of who works on Harley's is Howard at www.Motorcyclemetal.com.
If you take a look at any Buell or a rubber mount Sportster you will see they have three stabilizer links. The touring bikes, going back to the first rubber mounts, have only two, one at the front of the engine, the other between the heads. In addition, early bikes had cleve block swingarm bushings, which have a degree of flexibility in them. Finally, Harley has historically not used the best of tyres available. All three of these can contribute to that awful feeling some of us suffer from!
Tyres are easy to fix. There are several options, I prefer Avon Venoms - done! Cleve blocks can also be replaced by after-market solid bushings, which will improve handling and feel on earlier bikes. Harley replaced them with a better system around 2000 I believe.
But the main source of any handling problems is that the rear wheel and swingarm are mounted off the rear of the gearbox and the rear rubber mounts can flex a little. True-Track are one of the earliest to provide a solution, and at least a dozen other brands have jumped on the bandwagon. Their link IMHO comes closest to the Buell system of rear stabilizer and I have their kits on both my Glide and Dyna. My Glide now has their solid brass swingarm bushes.
Having fitted a Trackula kit to my dresser I have ridden it with and without the link. I cannot feel any difference in vibration. I have since replaced my motor with an S&S 107 and that is fine too. However the TT kit improves stability in ALL conditions, even riding in a straight line. It sharpens up the feel and accuracy of the bike and is a very worthwhile improvement.
I have had these kits for over 2 years and since before TT started advertising here on HDF - I went and searched them out!
Too many riders just hop on their bike and takeoff. Alot of riders just change the fluids and that is pretty much it. They apparently forget tire pressure, tire wear, suspension settings, and other critical fasteners.
The stabalizer items do work. If you don't ride it like a sportbike, then you probably don't need it. Then again, you probably shouldn't be riding it like a sportbike.
I ride older EVO Electra Glides and one with 180,000 miles. Neither has a Stabalizer kit on them. The tire pressure gets checked often, tire gets replaced before it is worn out, and all critical fasteners are checked. I keep desired air in the suspension as well. If a component is worn out, the bike is parked until that component is replaced.
My suggestions.....Quit riding like you stole it. Enjoy the ride, you'll get there eventually!
Don't skimp on any required maintenance! Do an inspection before every ride. When something critical is broken or worn out.....stop riding it and remedy the problem. If the bike suddenly does not feel right, have it checked out. Remember, handling degrades over time.
Handling is in direct correlation with age and mileage....
Would it make sense to install a Stabalizer kit when the bike has some worn out bushing or something is out of alignment?
