I thought I read that the Yellow jack sears...was not as sturdy...the lighter weight made it squirm with the bike on it.? Is the yellow jack lower than the red?..
I just sold my table lift...I only need a lift to move the bike around a bit and fluid changes and clean it...wheels are not easy to clean on a table lift.
No heavy wrenching goin on here...so just a cheapo sears lift for me .
I think.
Yellow
or Red
For my FLHX ...That is the question now?
I don't think the Read Sears jacks will work on any H-D bike that's lower to the ground than a stock Ultra or Road King Classic. I've use one on my Ultra and my RKC and it is a tight fit.
If you a haven't purchased a jack yet, I'd recommend ponying up a few more dollars and buy the yellow/aluminum jack. I had the red jack which worked okay, but the crossbare at the end made it a little clumsy at times. The yellow jack will go under a lowered bike a lot easier and there is no crossbar to deal with.
I sold the red jack after a year and have had the yellow one for 3-4 years, I like it very much. Until I get a table lift one of these days, the yellow jack is my best alternatrive.
I really wanted a Pitbull or JS Jack, but thought I could "settle" for something less, then I watched this video (there are more on there as well) I am using my fathers red craftsman right now and its OK, but nothing special. Bike wobbles on it, jack flexes. Wouldn't trust it for long periods and would NEVER try to move the bike while on it!
Stay away from that yellow jack, it's a wobblie piece of junk compared to the red jack, I bought one used it once and took it back. I have a RK that's lowered 1" and the red jack does not slid under it without holding the bike up or riding up on a piece of plywood.
I have an '08 FLHX and the red jack. My bike is lowered one additional inch front and back and I need to run it up on a 2x6 to slide the jack under it. If I recall, I even had to do that before I lowered it.
I do the same with my 09. Just use a scrap 2x6 and run the rear wheel on it and you'll be okay.
