Need help with a Power Commander V map
Old Jan 19, 2010 | 10:37 PM
Kevin9043's Avatar
Kevin9043
Default Need help with a Power Commander V map
I recently purchased a Power Commander V for my 2009 Road King with V&H Big Shot Duals and Arlen Ness Big Sucker Stage 1 A/C and I was wondering if anyone had an exact map for this setup. Yes I know i was dumb for not purchasing it through fuel motto but if anyone could help i would appreciate it.
Old Jan 19, 2010 | 10:44 PM
mongomark's Avatar
mongomark
If it becomes too much of a pain in the @$$, you might want to pop for the autotune. You could get that from Fuel Moto and then perhaps have access to their maps. I'd give Jamie a call.
Old Jan 19, 2010 | 10:46 PM
1sweetglide08's Avatar
1sweetglide08
Call Jamie from FuelMoto he may be willing to help you out.
jeff.georgalas's Avatar
jeff.georgalas
Or e-mail Jamie and tell him what your set-up is, and for a few bucks, maybe he'll send you a map that will work for you.
Old Jan 21, 2010 | 04:11 AM
joshuavlanderson's Avatar
joshuavlanderson
Default MAp
If you cant get it worked out then hit me back i have the same set up, Well close enough......I can send you the map i think. Let me know
Old Jan 21, 2010 | 05:37 AM
jrstar's Avatar
jrstar
09 RKC
I have the big shot duals, stage 1 air kit and stock ecm.
I have a map that was set up for this, one that is a little richer, and one that is a little leaner for better fuel mileage. I have my pcv on a switch to toggle between the rich and lean for city and highway. Shoot me a email if you need them.
Old Jan 21, 2010 | 07:26 AM
Kevin9043's Avatar
Kevin9043
hey jrstar, How do you toggle between the two. I am new to the PCV.
Old Jan 21, 2010 | 07:55 AM
Boo2you's Avatar
Boo2you
You should be able to download the exact map you need from Power Commander.
Old Jan 21, 2010 | 08:02 AM
Boo2you's Avatar
Boo2you
Go to http://www.powercommander.com/powerc...l_support.aspx and tell them what you need. They are good to answer your questions pretty fast or you can call them at 800-992-4993.
Old Jan 21, 2010 | 08:22 AM
jrstar's Avatar
jrstar
Just load 2 maps in the PCV and hook a switch up per power commanders website. It is just 2 wires you push into the PCV and tighten screws. One wire goes to one side of switch, one goes to the other. (open, close)
I did it a little different and used my accessory switch to power a relay to switch it.
