wiring for handlebars
Old Jan 25, 2010 | 10:06 PM
yoshitrain's Avatar
yoshitrain
Default wiring for handlebars
How are you guys depinning the harness to do internal wiring for the handlebars? Is there a special tool to help or how do they come apart?
Old Jan 25, 2010 | 10:13 PM
dawg's Avatar
dawg
release hook catch with needle nose pliers and pull up, then you can release pins with paper clip....assuming you're talking about molex?
Old Jan 25, 2010 | 10:14 PM
Harleypingman's Avatar
Harleypingman
The HD Service manual for your bike has an excellent description in the appendix.
Also, it's important to know the year and model of the bike since HD does change the manufacturer/vendor of the connectors from time to time.
You can also try googling Deutsch, Tyco AMP, and Molex since all have information on disassembling and reassembling connectors.
Old Jan 25, 2010 | 10:18 PM
PistonPuller's Avatar
PistonPuller
Yes its a tedious job but can be done. I used small flat precision screwdriver to release the pins. Make sure you make a sketch of the wires so you know how they go back. Manual tells how to do it as well
Old Jan 25, 2010 | 10:20 PM
yoshitrain's Avatar
yoshitrain
Sorry its for 09 streetglide. I believe it is the molex connectors. Ive done the ones on my 06 train but these are different. I looked in the book but must not of been hard enough. Thanks for the info and im off to check. Thanks again
Old Jan 25, 2010 | 10:25 PM
PistonPuller
look in Appendix A connector repair. Just know that the pin housing comes out with pliers, but has clips on the side. Use the small flathead or paperclip to get in there, then pull the housing out. Good luck
Old Jan 25, 2010 | 11:25 PM
fairplay's Avatar
fairplay
not enough patients for that. I just cut 'em, lengthen them, feed the wires and solder. I always seem to be putting taller bars on peoples bikes so this works for me. I would probably do the same even if the bars were the same length. Its just that much easier for me.
Old Jan 25, 2010 | 11:33 PM
hog-doc's Avatar
hog-doc
There is a special tool to open the secondary lock without damaging the connector, paper clips can damage them, then you have to replace the connector. Molex want $81.00 for the tool. Intermountain Cycle Products has them for $25.00
http://intermountaincycleproducts.co...Parts_ITTT.php
Old Jan 26, 2010 | 07:46 PM
bagger76's Avatar
bagger76
Just finished my 08 SG it took me awhile to figure out the connectors but in all i had the bars changed and rewired in a hour. best way to tell you is to first make a wire diagram then release the two clips on the inside the connector and pull the center out with small pliers then its all going to fall apart after you run your wires and are ready to put things back, The center your pulled out with pliers will lock in half way in the connector, now clip in all your wires once thats done finish locking down the clip,if you push the center in to far the wires wont push in. GLAD I CONFUSED YOU GOOD LUCK!!! its not that bad.
Old Jan 26, 2010 | 08:22 PM
Old Bones's Avatar
Old Bones
Paper clip works fine. Making a wireing diagram is a must.
galaxyfe
Jul 6, 2015 09:08 PM
jmerchant.1
Jul 2, 2014 11:44 PM
heepdriver
Feb 17, 2008 05:53 AM
stevodigitalfly
Flathead
Jan 23, 2008 02:20 PM
SMacDunk
Aug 12, 2007 11:35 AM
