charging problem
Old Jan 27, 2010 | 07:04 PM
rjcsnappy's Avatar
rjcsnappy
6th Gear
Default charging problem
hi, i have an 08 ultra classic, if i leave bike sit for a week, battery is stone cold dead, i bought it to harley a few months ago for a bad starter and asked them to check charging system,because the battery would go completely dead they replaced the bad starter and put in a brand new battery and and they said everything was fine, that was a few months ago, any way it still keeps going dead after a few day, and i mean 100% dead is anyone else having a charging problems,
Old Jan 27, 2010 | 07:11 PM
tombeving's Avatar
tombeving
Pull the connector from the voltage regulator to the stator. Start the bike and check the voltage. You should be reading 42 volts AC at 2500 RPMs. If your not getting this your stator needs to be replaced. Also check your battery with a volt meter while the bike is running. Sould be reading 14 volts DC.
Old Jan 27, 2010 | 07:26 PM
shortride's Avatar
shortride
If your bike is still under warranty you should let the Harley tech troubleshoot it. You should never assume a battery is good just because it is new. If a brand new battery was installed, the first thing you should do would be to fully charge it. Generally when a new battery is put into service, it is usually recommended to charge it. After fully charging the battery, and it continues to loose it's charge, you should have the battery load tested. It is not uncommon to get a bad replacement battery. After you resolve the problem, It's agood idea to use a Battery Tender when not riding.
Old Jan 27, 2010 | 07:30 PM
dawg's Avatar
dawg
Bring the battery in to HD. They will charge it overnight and then test it on the Midtronics battery tester. It will tell them if the battery is the problem. If the battery is good, try as posted above and start looking at various areas of the charging system such as stator and regulator. Also run the battery tender on the bike whenever it sits for a period of time.
Old Feb 2, 2010 | 07:04 PM
rjcsnappy's Avatar
rjcsnappy
6th Gear
Default charging problem??/
thanks for the imput, i called harley and they said they would come and pick it up, and yes its still under warrenty but i wanted some outside imput so if and when they tell me what they found i will some stuff to compare it to thanks again
cobra23
Jul 19, 2017 01:56 PM
lol_paul_ledoux
Electrical/Lighting/Alarm
Apr 6, 2017 09:02 AM
HDJIM1158
Aug 13, 2016 07:38 AM
JOW_103
Dec 29, 2014 03:49 PM
Booey424
Sep 18, 2011 11:45 AM
