Dynamat for Batwing
Old Feb 4, 2010 | 04:26 PM
Jday53's Avatar
Jday53
I just bought a 10 sq ft off ebay for $20 its not dyna mat but the off brand hope it works!!!! Noise killers is the company
Old Feb 4, 2010 | 04:37 PM
mastery's Avatar
mastery
It makes a difference, but not huge. As mentioned already, it helps with the bass, removes some of the audio vibration of the batwing, and helps redirect more sound back out the speaker port. Is it worth it? If you are an audiophile, in which you want to do every possible thing...yes...because you can tell a difference. If you are a average music listener, probably not.
I have it on my Ultra...and I like to think I'm an audiophile...and I noticed a difference, but I know what to listen for when comparing sound from 20 minutes ago when it wasn't there, and 20 minutes later when it was installed.
Old Feb 4, 2010 | 06:41 PM
Glenn W's Avatar
Glenn W
another option is the spray on variety. "Quiet Kote" VB-1S Pro from Cascade Audio Engineering works well. The 18 oz. can will do 2-3 fairings. I get it from Parts Express but I'm sure there's plenty of other sources.
http://www.cascadeaudio.com/car_nois...S_Pro_Tech.pdf
http://www.parts-express.com/pe/show...number=268-250
Old Feb 4, 2010 | 06:46 PM
bigskyhd's Avatar
bigskyhd
I installed it on the inside of my outer Dead Center Fairing. Can't say there's a huge difference but I thought it was crisper, and a littler clearer on the bass. Not nearly as much as I had originally expected. But better than original.
Old Feb 4, 2010 | 07:00 PM
7125's Avatar
7125
i did big change bought some from ebay
Old Feb 5, 2010 | 09:42 AM
electra glide's Avatar
electra glide
I have it, and for the $ it's a noce upgrade. It can't hurt.
Old Feb 5, 2010 | 06:49 PM
No Tyme's Avatar
No Tyme
I used about 4 square feet on the inside of my outer fairing: Brought out the mid-range... It was worth it!!!
Old Mar 5, 2010 | 10:34 AM
LUBA's Avatar
LUBA
Are you guys lining the whole inside of your batwing or just the sides by the speakers? I have my fairing out and was thinking of doing the whole thing and then adding the dynaxorb squares right behind the speakers (on top of the dynamat).
Old Mar 5, 2010 | 11:13 AM
shredsurf's Avatar
shredsurf
I'm VERY happy I had my RG fairing dynamated, definately gave me a deeper sound!
Attached Thumbnails Dynamat for Batwing-outer-faring-with-evenly-placed-sound-proofing-2-.jpg
Old Mar 5, 2010 | 11:18 AM
No Tyme's Avatar
No Tyme
I covered as much as I could of the inside of the outer fairing: about 4 square feet...
