It might be better to take it to a machine shop but this will work.. Machine shop can do it.. I wouldn't be surprised if WFO larry can do it. IIRC he's in oak lawn, ill.
It's an 07 flhp, the trans hole is badly wore, the shaft is very sloppy and the isolator on the belt side is also ovaled
This is sold by TrueTrack, it will allow you to drill out the swing arm shaft bore and install a brass bushing to eliminate the slop >>> http://www.true-track.com/tt_20-19l-rk.html
$230 for $80 worth of parts and tools? Sounds like good deal..
