Started my 95 Build
Old Feb 7, 2010 | 07:16 PM
Taylorized's Avatar
Taylorized
Post Started my 95 Build
Ran into a little trouble with a rear rocker box bolt. The front bolt on the left side is hitting the frame. Not threaded into the base but is tight againsit the frame. Can't get the rocker cover off. Did get the front all tore down will work on the rear tommorow.
Old Feb 8, 2010 | 01:07 AM
Ernie 06's Avatar
Ernie 06
Started my 95 Build-fall-2009-143.jpgjust started mine on monday good luck and have fun
Old Feb 8, 2010 | 01:12 AM
BadPiggy's Avatar
BadPiggy
The bottom of the crank case hangs slightly below the frame.
You have the motor raised with that jack.
Lower the jack.
Old Feb 8, 2010 | 06:18 PM
Taylorized's Avatar
Taylorized
Lower the jack.
Let the jack down and still wouldn't come out. Took the front motor mount loose and let engine come down to get it out.
Old Feb 9, 2010 | 07:59 AM
mainshaft's Avatar
mainshaft
Great project, I finished mine in Dec. Are you going with new cams??
Old Feb 9, 2010 | 08:13 AM
harley-jones's Avatar
harley-jones
It looks like you are having a good time. Thanks for the pics....
Good luck with your build.
Old Feb 9, 2010 | 09:10 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Looking good! Keep taking pics. We LOVE pics!!
Old Feb 9, 2010 | 09:12 AM
BigDaveOnBass's Avatar
BigDaveOnBass
I'll start my 95" build as soon as my heads come back from Big Boyz. Good luck and have fun!
Old Feb 9, 2010 | 11:52 AM
BadPiggy's Avatar
BadPiggy
That's what I like to see.
CARNAGE!
Never had a bolt on a Twinkie not come out.
Oh well...least it's out now.
If you have access to a "Motor Alignment Tool" you should check it when you reassemble...just for good measure.
Keep the pics coming!
Old Feb 9, 2010 | 02:22 PM
Taylorized's Avatar
Taylorized
Yes Cams Heads Pistons Pushrods
