SG floorboard bracket install
Old Feb 7, 2010 | 09:54 PM
tgshoe's Avatar
tgshoe
Default SG floorboard bracket install
I have a 2009 SG and am installing passenger floorboards in place of the pegs that it came with to make the wife more comfortable. The problem I am having is that the lower bolt is supposed to be torqued to about 40 inlbs then you move the bracket to line up the upper bolt at the height you desire, only once the lower bolt is torqued you can't move the bracket as it is tight. If you try and leave it loose and line up the upper bolt first the lower bolt is up in the bracket and pretty much inaccesible. The lower bolt is a shoulder bolt and this kit is the Harley kit for the SG with the Streamliner inserts. I realize the lower bolt is mostly for antirotation purposes but want to make sure as I want to be safe. Most brackets I have seen including the one that came off has a pin in the lower position and is only held by the upper bolt. Has anyone installed this bracket and had this issue and how did you address it? Thanks. I did try search but only came up with a bunch of misc. threads about bolts breaking and such.
Old Feb 11, 2010 | 04:25 PM
tgshoe's Avatar
tgshoe
No one installed a passenger floorboard kit on their SG?
Old Feb 11, 2010 | 06:32 PM
bald1der's Avatar
bald1der
I installed floorboards on my 09 SG. Unfortunatly I didn't have any problems with the install. I have the bolt installed the bolt in the second hole from the top and the pin is in the next hole.
Old Feb 11, 2010 | 07:45 PM
tgshoe's Avatar
tgshoe
You must have the brackets like I am used to seeing. Bolt on top with pin on bottom. This kit has a bolt on the bottom and the top and the bolt on the bottom instead of being in a hole is in a slot so you can move the bracket up and down to install the upper bolt at the desired height, only after torqueing the lower bolt you can't move the bracket. The kit I got is HD #50378-07B.
Old Feb 11, 2010 | 08:07 PM
TexasTim's Avatar
TexasTim
Don't torque the lower before putting the upper in. Just finger tighten then torque em both down when its where you want it.
Old Feb 11, 2010 | 08:15 PM
bald1der's Avatar
bald1der
I dug through my records and found the instructions sheet for my kit. The kit I have is 50378-07. I'm assuming the 50378-07b must be a "new and improved". LOL seems new and more complicated...
Old Feb 11, 2010 | 09:30 PM
tgshoe's Avatar
tgshoe
Once the bracket is at the desired height you can't get to the lower bolt as it is up inside the bracket. I tried that. But thanks for the suggestion.
Old Feb 11, 2010 | 10:46 PM
vzts4q's Avatar
vzts4q
Looking at the instructions it says the bottom screw is a shoulder bolt. That being the case it should not tighten up on the bracket! If it is getting tight then screw is to short or the bracket is a little to thick.
Old Feb 12, 2010 | 03:25 PM
tgshoe's Avatar
tgshoe
That is the conclusion I have come to. It is a shoulder bolt. Pretty sad for a $300 kit to not fit correctly.
Old Feb 15, 2010 | 09:21 PM
wtb3886's Avatar
wtb3886
Default Just a thought
Greetings from SC, all I did was removed just the passenger pegs and and attached the HD floorboards, then bought the clamps and attached the pegs to my crash bar.
See my photos in my profile of the HD Floorboards & Pegs installed.
Ecker27
General Topics/Tech Tips
Jul 2, 2019 03:46 PM
Dub_jr.
May 31, 2016 07:59 AM
monster715
Mar 18, 2014 10:09 PM
ShockwaveTXB
Jul 14, 2013 11:30 PM
papejr
Mar 18, 2012 10:30 AM
