electrial connection
Old Feb 8, 2010 | 01:40 PM
bikerick's Avatar
bikerick
Default electrial connection
having removed my tour pack i cut the wires next to my seat..iam looking for a 3 wire connection that when the pack is off i can seperate and cap 1 end and tuck it under my seat..i have been looking but no luck..
Old Feb 8, 2010 | 02:20 PM
vzts4q's Avatar
vzts4q
Default connectors
Here is where I get mine.
http://www.deutschconnector.com/
http://www.deutschconnector.com/prod...onnectors.html
Old Feb 8, 2010 | 02:46 PM
MINI SSS's Avatar
MINI SSS
What tool do you use to crimp the pins? Can you simply solder instead of buying the $ 200 tool?
Old Feb 8, 2010 | 04:40 PM
Skip's Avatar
Skip
If you are careful, you can crimp them with an ordinary wire crimping tool and a pair of needle nose pliers to finish it off.
Old Feb 8, 2010 | 04:45 PM
vzts4q's Avatar
vzts4q
No didn't buy the high dollar one. I used the crimp tool I already had for GM weatherpack terminals. I think it may be this one. http://www.amazon.com/Delphi-Packard.../dp/B002CCAEJ6
Looks like Sears also has one. http://www.sears.com/shc/s/p_10153_1...21x00003a#desc
Also found others using a search for GM Weatherpack or Deutsch crimp tool.
Old Feb 8, 2010 | 08:56 PM
Harleypingman's Avatar
Harleypingman
I use the BCT-1; $25:
http://www.greatplainselectronics.co...cts.asp?cat=53
Does an excellent job on Deutsch, AMP and Multilock sockests and pins.
A cheaper alternative is Philmore WS26; $10 at Fry's Electronics. Use this for a couple of years and works fine; but, the BCT-1 works better--less dressing of the crimps.
nashspu
May 5, 2014 06:33 PM
Brew61
Audio Systems
Apr 24, 2014 01:41 AM
V2Evo96
Apr 18, 2011 06:19 PM
lowridernj
Feb 15, 2009 09:23 AM
ronyd
Dec 16, 2007 06:08 PM
