Neck Bearings
Old Feb 19, 2010 | 11:53 AM
RexBuck's Avatar
RexBuck
Originally Posted by Unome
2. Anyone used anything else besides the "tool" they tell you to make to do the adjustment?
I'm going to have to see about finding an aluminum rod and handfiling it down it that's the only way to do it.
I used an old screwdriver - ground it and bent it according to the specs in the manual.
Old Feb 19, 2010 | 01:22 PM
twincam47's Avatar
twincam47
unless you want to take the chance of getting hurt because of handling irregularities...follow the procedures in the service manual for this. Also check for any tech bulletins where the swing away test has been modified since the printing of the service manual.
the Steering Head bearings are the only link between the front and rear of the motorcycle. your life could depend on proper adjustment.
Old Mar 16, 2010 | 01:21 PM
Unome's Avatar
Unome
Default 1 Last Question(Until The Next One)
I didn't get a chance to do this yet but hope to this weekend. I have the manual & Fix My Hog DVD.
Watching the DVD, they take off the throttle & idle cables and the clutch cable. And then they do the swing test.
In the manual, this is not mentioned. It's just "get bike up off ground and perform swing test and here's how far it should swing to be correct".
Should the cables be removed before doing the swing test on a 2007 FLHTC?
TIA Folks!!
Old Mar 16, 2010 | 04:09 PM
hog-doc's Avatar
hog-doc
Originally Posted by RG32
Thanks guys,before I posted I read the (fall away) method,but felt there was a more practical way of doin the check.If one side of your handle bars weighs more than the other(I-pod holder,brake resevoir on one side,not the other, for example), it is naturally gonna fall to that side,with modern tech know how, I think there would be a better way.I like the idea of grabbing the forks and checking for slop. JMO... Thanks again.
There is a more practicle way, run it down the road, get to 50 mph and let go of the bars but keep your hands close to the grips, as you deccell from 50 down to 30 it should stay steady. If it starts to wobble the bars back and forth it is loose!
Always final check with the fall away meathod though, new spec is stopping in the 4th swing, old was in the 3rd. I like to set mine to stop at the end of the 2nd swing!
RagmanZL
2014-2024 Touring Models
35
Aug 27, 2018 01:56 PM
flhtupser
May 12, 2012 02:03 PM
10Dyna
Sep 3, 2010 05:52 AM
crepe
May 17, 2010 07:02 AM
Uncle Scrooge
Feb 9, 2007 02:32 PM
