Engine Gurus please step inside
Old Feb 10, 2010 | 09:59 PM
hog-doc's Avatar
hog-doc
Originally Posted by Crusher
I guess I'm not phrasing my question correctly so I'll try again.
I plan on a 103 upgrade from one builder using all the matching parts from one vendor.
I'm interested in low end power not high end power and will have a cam that will achieve that.
My exhaust is somewhat restricted so it doesn't flow as well as most after market.
I'm having head work done to match the 103 kit.
My question only has to do whether to include larger valves in the head work. I've gotten two different answers from two different builders, so 'm asking here for any opinions. So far I've gotten a lot of good advice but no one has offered an opinion on the valve question or I'm just not seeing it.
First off why dont you list WHAT parts your using to make it easier to determine IF you need bigger valves, and if you want to keep the Super Trapp slip ons why not add a set of V&H 1 3/4" true dual head pipes to eliminate the restrictive stock head pipes? Wont change the sound level or volume but WILL help with the flow!
Old Feb 10, 2010 | 11:51 PM
genedjr's Avatar
genedjr
Default Pick a builder
Choose what the builder recommends. Builders have favorite setups for just about everything. They have played with the mix (and screwed up bunches) to get the max out of the budget and performance you want.
But I expect the builder will want you to look at your intake/exhaust to complement the great work he will do.
So - if your spending your hard earned $$$$$ with a builder - then go whole hog and trust what he has in his 'WOW' bag.
...gene
Old Feb 11, 2010 | 04:55 AM
smokindave's Avatar
smokindave
Based on what you have said, think about using your stock valves and just recutting valve seats and valves to a more radius profile to allow the heads to flow better. This along with port and polish should allow a better flow in the heads.
jmd897
Feb 14, 2017 05:19 PM
moeo7
Jul 18, 2014 02:24 PM
jrsdws
Dec 30, 2011 09:44 AM
bobby5
Exhaust System Topics
Jul 15, 2010 04:38 PM
Hubcity2
Oct 28, 2008 09:40 AM
