Steering neck - over lubed?
Old Feb 11, 2010 | 05:22 AM
patsfan's Avatar
patsfan
Originally Posted by EasternSP
If its leaking a little grease in the winter temps, just wait till things warm up. You might consider using higher temp grease so it doesn't run on ya. I did mine over a year ago and I don't recall the name on it. Hasn't run at all.
I used the harley brand grease and it hasnt been oozing latley, only cause our temps have been 45-70, mostly. The weeping came back in Oct/Nov when we had consistently high temps in mid 80s.
Thanks to all for the responses, I'm going to properly check the neck this weekend.
Old Feb 11, 2010 | 11:03 AM
skratch's Avatar
skratch
I'm going to properly check the neck this weekendI'm going to properly check the neck this weekend
just be aware that the specs in your manual may or may not be accurate anymore. dawg had previously sent me a bulleting from hd that changed the number of swings on the fallaway test. actually increased the number by one.
Old Feb 11, 2010 | 11:25 AM
FastHoss's Avatar
FastHoss
I put the chrome wind deflectors on my and could feel the wiggle,took them off after a couple of weeks.Could not feel it all the time but if conditions were right I could.
Old Feb 11, 2010 | 11:34 AM
Damascus's Avatar
Damascus
Originally Posted by SG_Dave
Get a manual and do the swing test. You may just be loose.
+1. The wheel should only bounce back and forth 3 - 4 times per the manual. (I don't have it with me right now.)
A high speed waggle could be a real bummer.
Old Feb 11, 2010 | 05:46 PM
skratch's Avatar
skratch
here is where you can download the hd bulletin with the new specs for the fallaway.
thanks to dawg!
fallaway bulletin
Old Feb 11, 2010 | 05:50 PM
HDV-GLIDE's Avatar
HDV-GLIDE
That's the problem, the HD grease is not thick grease and will run out when things heat up....
Old Feb 11, 2010 | 05:54 PM
dog155's Avatar
dog155
You can over grease the triple tree,too much is just wasting grease.Anytime I ever feel the need to tear into the steering head always wipe bearings clean and use high temp grease,that resists dripping.Think about how little this bearing actually moves.
Old Feb 12, 2010 | 04:48 AM
1st 96 ultra's Avatar
1st 96 ultra
just woundering why the bearings need to be greased inbetween replacement or assembly , I am a mechanic on industrial equipment so I am not dumb but the bearings move so little I don't under stand why they need to be greased ? I can understand the adjustments because of the pounding they go through but not the grease inbetween replacement , can someone make me smarter , thanks
Old Feb 12, 2010 | 05:11 AM
patsfan's Avatar
patsfan
Originally Posted by skratch
here is where you can download the hd bulleting with the new specs for the fallaway.
thanks to dawg!
fallaway bulletin
Thanks for the link
Old Feb 12, 2010 | 08:33 AM
twincam47's Avatar
twincam47
I would only use the H-D recommended grease even if it drips when it gets hot. Using grease of a different viscosity WILL SKEW the results of the swing away test. A thicker or thinner grease will affect the swing test results. This will make the neck bearings either tighter or looser than spec., which could result in a handling irregularity.
Think about it...thicker=more drag....thinner=less drag...the overall result of the swing test are affected by these factors and the clamp load on the bearings.
