Deutsch Pin Part # Help
Old Feb 13, 2010 | 11:13 PM
dawg's Avatar
dawg
oops, yes HP has it right 72190-94 is the male stamped and formed pin. I was looking at the wrong line, hence the seal pin pn#
bikerbehaviorist's Avatar
bikerbehaviorist
dglide I would be interested in what you are doing. I just took an alpine out of my fairing because the cd player went in 18 months and replaced it with a pioneer head unit. I love the unit except for the volume controller **** - it is too small with gloves on. I have been using a wireless remote, but also have been looking at making a four way switch for volume and forward and back tracks. My understanding this is a matter of send a specified resistance from between the base and tip of the 3.5 in. stereo plug that is used.
I have also used a regular crimper for these pins for connecters I have made for my detachable fairing and it work just fine!!
Last edited by bikerbehaviorist; Feb 13, 2010 at 11:16 PM. Reason: add more blah blah blah...
Old Feb 14, 2010 | 09:27 AM
DGlide04's Avatar
DGlide04
What I would up doing was swapping out the stock RK handlebar switches for a set from an E'Glide w/o the cruise, the ones with only 1 additional hole in the lower switch housings. I bought the stock Mode/Volume switches from my local dealer and will be wiring them to the detachable fairing through a pair of Deutsch connectors, one for each handlebar side switch. Easier to operate the radio and it's still detachable when and if the fairing ever comes off.
The Alpine head unit will be connected to the switches through a module from PAC audio and you're right, it is a matter of wiring them through the resistors supplied with the PAC unit, I think 3 wires in all.
I'm looking forward to getting the new Wild 1 handlebars wired up internally this weekend and with the help of a few helpful members here, I've got the part numbers to order the final pins and plugs that I need to finish everything up.
Sorry for the long reply, I hope this helps.
Old Feb 14, 2010 | 10:49 AM
BadPiggy's Avatar
BadPiggy
Although I'm not a fan of extended warranties...in the case of the Pioneer I put in my SG...I bought it.
Bought the head unit at Best Buy and because I knew where I was putting it, I paid the additional $15 bucks for a 4 year, no questions asked warranty.
delrey737
Biketronics
Mar 15, 2017 08:13 PM
ZBARK
Touring Parts
Sep 30, 2015 12:39 PM
hdlurker
Sep 8, 2013 11:27 PM
htrddah
Aug 14, 2010 01:36 PM
pauled
May 23, 2005 07:08 AM
