Stereo Upgrade -Stator/Rectifier Question
Old Feb 15, 2010 | 10:44 AM
BadPiggy's Avatar
BadPiggy
Default Stereo Upgrade -Stator/Rectifier Question
Guys,
I have a 500w Memphis Audio Amp and 2-10" Memphis Audio Subs sitting in my shop taking up space.
I'm thinking about storing these in a chopped tour pack for the time being.
Since they'll be sitting in the tour pack...might as well hook the damn things up, RIGHT?
My main concern is the charging system.
Anyone know the amp rating on the stock stator/rectifier?
Anyone know if there is a larger setup available?
I'm also considering the ARC 125.2 for the front speakers that I'll change to 6 1/4"'s and a set of the Not-Yet-Released-RG Hogpods.
If I can make this work with no charging/electrical problems...this system should be the cats-***!
ANY info/help would be appreciated!
EDIT: This is for a '09 Road Glide
Old Feb 15, 2010 | 10:50 AM
07RoadHawg's Avatar
07RoadHawg
I "think" I read in the manual for my '07 King that it's 44 or 45 amps.... That's from memory when I was looking at heated gear....
Old Feb 15, 2010 | 02:39 PM
twincam47's Avatar
twincam47
Stock is 50 amp 3 phase...nothing bigger from H-D
Maybe aftermarket?
Keep in mind if the amplifier pulls too much juice the ECM/injectors will fail and you can create all kinds of driveability problems.
Old Feb 15, 2010 | 09:28 PM
kruzin's Avatar
kruzin
Been running a 500 watt Sony XPlod for 2 years in my 2006 Road Glide....No problems.
Old Jan 1, 2011 | 03:10 AM
eds06roadglide's Avatar
eds06roadglide
Check out my signature....I'm pulling over 800 watts and not issues. Now if the bike is not on iI have about 25-30 minutes before I'm stuck....
Old Jan 1, 2011 | 11:48 AM
GLACIERPEARL's Avatar
GLACIERPEARL
My system pushes 1200 watts through 2 Alpine PDX 4.150's.
Haven't had any issues through 2 summers.
Did buy an additional battery last summer, to run a 2 battery system.....but never got around to it.
Somewhere there is a thread floating around about how to have both batteries hooked up at all times, with the charging system switching back and forth between the batteries. I'll have to look that up !!
penmaker
Audio Systems
Jul 13, 2018 06:32 AM
mrsnipy
Jun 27, 2018 08:55 AM
marcodarq
Audio Systems
23
Jan 30, 2018 03:08 PM
Bunker
Audio Systems
Jan 28, 2016 08:57 AM
rmwrip
Jan 30, 2009 06:30 AM
