Road tech GPS charging help
Old Dec 31, 2010 | 05:50 PM
hxturbo1's Avatar
hxturbo1
Default Road tech GPS charging help
I have the 660 and on the back of the car mount there are two ports. One is for the cigarette charger and I thought the second was for the a/c charger. When I plug it in the screen says the device is not supported. What is that port for and is the only way to charge the unit my house through the port under the battery cover? Both of those ports are identical to the USB cable and the a/c charger cable.
Old Dec 31, 2010 | 06:13 PM
Morris9982's Avatar
Morris9982
It could be for an external antenna. Do you have the papers that came with the mount? If so, they should show the use for the port.
Old Jan 1, 2011 | 11:52 AM
Dave2261's Avatar
Dave2261
I thought the second port is for a audio out cable to plug into you car's stereo ( if you have the plug) so you could listen to mp3s or audio books you may have install in the GPS. Kind of like how you have to plug it into aux in on the front of the bikes radio.
PingJockey
General Topics/Tech Tips
Jan 6, 2017 03:30 PM
lawman1841
Jan 26, 2013 03:41 PM
goosehntr
May 31, 2012 07:57 PM
Hawnted
Aug 4, 2009 02:02 PM
Fatboy2
Oct 29, 2006 11:56 AM
