New RKC Questions
Old Feb 18, 2010 | 10:45 PM
MarineBagger's Avatar
MarineBagger
Default New RKC Questions
Hey all,
Just bought a 2010 RKC, and I have been riding a 98 Fatboy for a number of years and got used to it's sounds and just want to check that some of what I hear on my RKC is normal.
I hear a lot more valve noise than I am used to. It doesn't sound bad, just loud. In first gear the tranny whines a bit, especially on accel and decel. The shifter makes a noticeable "clunk" when I shift. I'm not stomping on the shift lever, but I am surprised at how loud it is.
Are these sounds normal, or do I have an issue that needs to be addressed?
Thanks,
Old Feb 18, 2010 | 10:58 PM
Carmell RKC's Avatar
Carmell RKC
I know exactly what you mean, I notice the same thing switching between my NT and RK. Those things you describe sound perfectly normal to me, my King has been doing it for 4 years with zero problems.
Old Feb 19, 2010 | 07:53 AM
MarineBagger
Thanks Carmell. Anyone else out there hear these same sounds?
Old Feb 19, 2010 | 08:05 AM
WildBillAce2's Avatar
WildBillAce2
It's normal, but you can reduce the tranny noise and clunk with a good synthetic gear oil. I use Mobil 1 70/140
Old Feb 19, 2010 | 08:38 AM
Toypuller's Avatar
Toypuller
Normal.
My valve train noise seemed to quiet down about 50% after the first couple thousand miles. I also switched up the oil to Mobil 1 V-Twin Syth.
The clunk will also reduce after first adjustment and fluid change with a good synthetic.
Old Feb 19, 2010 | 08:41 AM
Pumba11's Avatar
Pumba11
Normal.
If your FatBoy didn't have a windshield, that makes a big difference also. It kicks engine noise back into your face
Old Feb 19, 2010 | 08:45 AM
BigGdawg's Avatar
BigGdawg
Probably the windshield is bringing the normal noises to your attention. You wouldn't have noticed as much on the Fat Boy without a windshield. Is the clunk on shifting into first gear when starting (normal) or when driving? Abnormal. If the latter get it checked.
Old Feb 19, 2010 | 08:47 AM
69z28's Avatar
69z28
Sounds like normal twin cam noise,you didn't mention miles but they tend to quiet down some after some miles.Syn oil will also help.Get used to the trans clunk.
Old Feb 19, 2010 | 10:53 AM
bob46371's Avatar
bob46371
2009 FLHRC Vivid Black
Take the windshield off and go for a ride.... it changes everything
Old Feb 19, 2010 | 12:17 PM
bobbydeuce's Avatar
bobbydeuce
Default 09 flhr
I recommend Red Line Heavy ShockProof Gear Oil
