Tent, sleeping bag, etc.
Old Feb 21, 2010 | 09:05 AM
big_e78's Avatar
big_e78
Default Tent, sleeping bag, etc.
I have a sleeping bag, tent, inflatable mattress and a rainsuit that are fairly small. All are stuffed down to 8-9" in diameter and from 12-24" long.I have a solo seat with a luggage rack mounted to the fender (I also have a passenger seat and backrest if needed). Would a cargo net attached to the luggage rack be the best way to carry these? I only ask because the cargo net seems that it would still allow my stuff to shift around somewhat. Has anyone else ever done anything different that works well?
Old Feb 21, 2010 | 09:17 AM
nocarb's Avatar
nocarb
2 bunjee cords will work fine. I have 2 that have plastic hooks but they are hard to find. I would like to get a couple more but I can't seem to remember where I bought them.
Old Feb 21, 2010 | 09:23 AM
DPete's Avatar
DPete
Yeah, before I had a tourpak I just bungied that stuff to the passenger backrest sitting on the passenger seat. If you do it right you get a backrest for yourself out of the deal. Plastic hooks are a must not just plastic coated
Old Feb 21, 2010 | 09:25 AM
Theakerr's Avatar
Theakerr
Nowadays I NEVER use a cargo net or bungee cords. Those hooks, even thought they are coated in plastic, are hard and sharp and when loaded up under the tension of the elastic are like missiles aimed at the eyes or other facial soft spots (my wife is a nurse - she knows and a number of years ago i had one break the lens on my glasses). Today, I always use tie down straps available from most hardware and automotive stores. These straps also stop the load movement that you often get from cargo nets, load movement that often results in a wear patch on your paint. My 15c worth
Old Feb 21, 2010 | 09:26 AM
dougbk's Avatar
dougbk
BUNGEE! You can also add the cargo net over it for a little extra if you desire.
Old Feb 21, 2010 | 10:50 AM
coolhands03bagger's Avatar
coolhands03bagger
heres a tent, air mattress, blankets, and a chair on the passenger seat. I use the back rest also. The yellow bag is water proof. It all makes for a nice backrest. I use bungees and a lot of them to make sure this stuff doesn't fall off. It doesn't hurt to put a few extra on. Good luck.
Old Feb 21, 2010 | 12:37 PM
BLACK 3's Avatar
BLACK 3
thats the same thing i did when i had a Fatboy and still used a cargo net.
Old Feb 21, 2010 | 12:59 PM
Gofer's Avatar
Gofer
I use two bungee cords and then put the cargo net over it. I figure the cargo net will catch any flying bungee cords as well as a good place to tuck maps, etc...
Old Feb 21, 2010 | 01:49 PM
Mike's Avatar
Mike
Learn how to tie a truckers hitch. I can't diagram it for you here, but you can look it up easily. It is simple to tie, and you can tighten a load down better with it than you will ever get with bungee cords. Get a couple of 6-8 foot sections of braided cord. It packs easily in your saddlebags and you'll be able to secure just about anything.
Get quality rope. Nylon or Dacron. Stay away from that cheap yellow polypropylene stuff. It doesn't tie well, and it breaks down in prolonged UV exposure.
Old Feb 21, 2010 | 03:23 PM
big_e78's Avatar
big_e78
Not a bad idea...I'm always worried about something shifting and losing all my stuff without knowing it.
