Removing fork legs
Old Feb 24, 2010 | 12:59 PM
yank's Avatar
yank
Default Removing fork legs
Last month I removed my fork legs on my 03 flh with ease to replace the fork sliders. I am now helping my friend remove his 07 flh legs but they do not want to come out. We removed the top bolt, took off the pinch bolts but that sucker will not budge. Anyone have any tips or problems with their 07. HELP! Called a few harley dealerships and a few mechanics and they all say the same thing that it should slide right off.
Old Feb 24, 2010 | 01:16 PM
tombeving's Avatar
tombeving
I had that with an 05 Road King once. Left side seemed to be stuck. Put the top bolt back in hand tight and sprayed it with penetrating oil and let it sit for about 20 minutes, and it started moving a little. Sprayed it again and let it sit. Finally got it to slide out. It was slightly oxidized.
Old Feb 24, 2010 | 01:39 PM
timvan's Avatar
timvan
are we talking seperating sliders or the fork legs from the trees?
If seperating, remove the lower bolts on the BOTTOM of the for legs and they will slide apart
Old Feb 24, 2010 | 09:31 PM
yank's Avatar
yank
just talking about the legs from the triple trees.
Old Feb 25, 2010 | 01:15 PM
yank's Avatar
yank
got it off using a strap tool to wiggle it out. corrosion had already settled on the upper triple tree which caused it to stick. thanks for the comments.
Old Feb 25, 2010 | 02:21 PM
HDV-GLIDE's Avatar
HDV-GLIDE
I applied a thin coating of Never-Seize to the inside of the trees for easy removal next time....
Old Feb 25, 2010 | 02:30 PM
Beemervet's Avatar
Beemervet
Put top plug back in a bit then use the persuader tool.
JekyllnHyde
Jun 12, 2019 07:31 PM
YeOldeStonecat
Shovelhead
14
Jul 22, 2014 11:55 PM
Smokin 03
Aug 28, 2013 08:34 AM
883drummer
Shovelhead
Apr 7, 2013 07:43 PM
meepers
Apr 5, 2010 11:40 AM
