Power Commander V Question
Hi all,
I just installed FuelMoto's stage 1 kit, and a set of SE255 cams, on an otherwise stock 2008 Road Glide. The bike runs well, and pulls strong, but the rev limiter kicks in at around 5000-5100 RPMs. When installing the map to the PCV, I opened the map that FuelMoto sent for those specs, and clicked "Send map" and "Send Table". Have I done something wrong, and if not, how do I change it? Thanks.
Joe
2008 Road Glide
Joe
2008 Road Glide
Due to the strategy on 2008 and newer drive by wire models and the way the tach is wired, with the PC-V RevXtend the tach will stop at 5100 RPM although the motor will continue to rev to 6200.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
If you have the stage 1 download the tach will read to 6200 RPM becuase the PC-V does not need to drive the signal.
redturbo911
Apr 18, 2016 08:25 PM
