First ride
Old Mar 2, 2010 | 05:30 PM
dawg's Avatar
dawg
Originally Posted by UltraKla$$ic
Watcha think is going on in the primary? It's plug and play as you know so I'd be interested in hearing WTF you left out/off. LOL!! Seriously, hope it's nothing serious and let us know.
Didn't leave anything off. I just didn't like the rattling and clanking that it was making. When you fill the wedge with oil and put the spring in it, you have to put it back in the sleeve. In order to get it in the sleeve and get the hook on it to close it for install, you have to push it on the sleeve pretty tight. I think that it may have not loosened enough and there was slop in the chain. I took the cover off and tapped on the rear of the wedge and moved it out a little bit to more tension on the chain. I gotta put some fluid back in and take it out again when I get a chance to see.
Old Mar 2, 2010 | 06:22 PM
TheBagger's Avatar
TheBagger
I got my first ride in yesterday. Pretty chilly on the highway so I made it a short one. Now it's colder today and some hail off and on....crap.
Old Mar 2, 2010 | 07:09 PM
KoalaCowboy's Avatar
KoalaCowboy
ah......now that is what I call a refreshing way to end the work day! 90 mile ride just to blow the cobwebs out...
Old Mar 2, 2010 | 07:19 PM
The Old Man's Avatar
The Old Man
I got out today round trip to work was 15 miles or so each way. Sure felt good.
Old Mar 2, 2010 | 09:08 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Thumbs up
Figgered it was slack, but ya never know. Let us know how you like it.
Old Mar 7, 2010 | 06:52 PM
Hinzy's Avatar
Hinzy
Interested if you had another ride dawg
regarding the SOHB tensioner
Old Mar 7, 2010 | 07:32 PM
dawg's Avatar
dawg
As a matter of fact I did. I took apart my primary three different times. After talking with Herko and getting some machinist advice from soos I had to do a couple of things. I had to take the unit out and I had to fix the indents in the back of the unit where the spacers sit as they were off. I had to take the shaft off and polish it and chamfer the top of it as it wouldn't slide in the hole in the wedge. I finally got it to work properly. I was going to put a shim in the spring or get a stiffer spring, but I didn't. However, when riding it today there was no chain slap, but if at a higher RPM and when I left off the throttle I could hear the wedge vibrating a little bit. I think that a shim inside the spring in the shaft will help that or a stiffer spring. It's still a shame that one has to basically rebuild this thing because of **** poor tolerances by SOHB.
Old Mar 7, 2010 | 07:49 PM
Hinzy's Avatar
Hinzy
Thanks for the update dawg,
so much for the greatest tensioner
since sliced bread
Old Mar 7, 2010 | 07:57 PM
dawg's Avatar
dawg
In all honesty, if you look at the OE HD tensioner you could accomplish the same thing by filing/grinding off the notches in the bottom of the wedge and/or the base of it. You would then wind up with the exact thing that the SOHB wedge is accomplishing, but you would have better tolerances and the thing would probably work better. I am going to try and put a shim in the spring or get a stiffer spring and I think that will combat the vibration of it at decel as it would hold it tighter against the bottom of the pad.
Old Mar 8, 2010 | 08:12 AM
Hinzy's Avatar
Hinzy
Keep us updated dawg,great info as always
hdgzr
Mar 24, 2011 09:13 AM
masterblaster
Members Meeting Members
15
Dec 7, 2008 05:50 PM
easyglider
Mar 10, 2007 03:56 PM
