Maps... Help a girl out
Old Mar 5, 2010 | 09:41 PM
WI Bob's Avatar
WI Bob
+2 or +3 or whatever on the calling Fuel Moto.
They make these things run with an email.
Then you can go have dinner wherever you wish with the guest of your choice.
Old Mar 6, 2010 | 08:02 AM
TittiesOnTwo's Avatar
TittiesOnTwo
This ain't my first rodeo guys! I used to have race bikes so I am very familiar with tuning There are lots of "tuners" in my area but only a few good ones. The particular one I like just works his mojo with the ladies and I am not impressed. Will I have to pay him? Why yes but he never stops at that. It's like a wart that won't go away
At any rate I did call Jamie and he is going to give me a hand with my problem. For now I have adjusted the fuel column and on my ride last night there was less popping.
Old Mar 6, 2010 | 08:20 AM
badwiser's Avatar
badwiser
the auto tune may be your best option.
Old Mar 6, 2010 | 01:18 PM
iclick's Avatar
iclick
DJ recommends no target AFR's in the 0% column, so if you follow their advice AT likely won't help with decel popping. OTOH if your 0% throttle-position setting is incorrect it might affect it. For example if it is showing 5% at idle it will be reading from the 5% column of any given table (base map and ignition timing, plus targets and trims with AT), which may be the problem.
I have all zeroes in the 0% column of my Target AFR tables and all negatives (all -10's above 2500rpm) in the base map, and I have no decel problems. Actually, I've never had any even when I had all zeroes at 0%.
Old Mar 6, 2010 | 06:12 PM
sportyrider1's Avatar
sportyrider1
if you still need a good tuner Give the guys over at Hog wild of Temple a call they are about 10 - 20 miles west of six flags off I-20 did a great job on my 03
Old Mar 6, 2010 | 06:42 PM
Sancho's Avatar
Sancho
Originally Posted by TittiesOnTwo
Hey guys my PCV was given to me as a gift. I am really wishing I could return it and buy one from Jamie at Fuel Moto cause now I am stuck. There is no map for the 2010 SG and Fat Cats with a Screamin Eagle High Air flow kit (I believe, it was also given to me) I went with Power Commanders advice and used the Map for the Thunderheaders but I am still having some popping on decel in 2nd gear. Does anybody have a custom map that they have used? Even one for an '09 bike would be nice since the motor was the same.
I just sent you a pm. I have the map you need.
Old Mar 6, 2010 | 06:54 PM
cuda67bnl's Avatar
cuda67bnl
And there you go! I was wondering how long it would be before someone had it.
Old Mar 6, 2010 | 08:12 PM
Jebster's Avatar
Jebster
Sancho! You're the Man!!
Old Mar 7, 2010 | 07:30 AM
harleytuner's Avatar
harleytuner
TBW bikes don't idle at 0%, they idle at around 4-5%
Old Mar 7, 2010 | 10:16 AM
Jambon1's Avatar
Jambon1
Yeah and he's married.....
That's good..........at least he won't be looking for a long term commitment
vickers1
Jul 21, 2012 01:40 PM
iron_rider
Jul 8, 2012 08:31 AM
10350
Sep 28, 2011 05:25 PM
pittz5
Feb 19, 2011 05:21 AM
bobbydeuce
Aug 12, 2010 04:48 PM
