Primary Wear
Old Mar 7, 2010 | 12:48 PM
OnTheFence's Avatar
OnTheFence
Default Primary Wear
I drained my Primary fluid yesterday, and was a bit surprised. I held my finger in the stream for a few seconds and found that when I smudged my thumb and forefinger together, my finger looked as though I had just stuck it in silver paint.
The inside of the inspection cover was coated in silver as well.
I followed the manual and went 10,000 miles using Mobil 1 V-twin.
Is this normal wear?
Old Mar 7, 2010 | 12:54 PM
dawg's Avatar
dawg
Personally, I don't like using synthetic in the primary let alone regular engine oil. I use Dexron III ATF, but that's just my opinion. What did the magnetic plug look like?
Old Mar 7, 2010 | 01:25 PM
07RoadHawg's Avatar
07RoadHawg
I've always had dark gray oil (never stuck my finger in the stream) and a few shavings on the drain plug when I change my fluid. I do it at 5000 miles along with the engine oil since it does get full of used friction material and a little metal from the steel plates. Might be overkill, but it's just what I do.
Old Mar 7, 2010 | 01:48 PM
OnTheFence's Avatar
OnTheFence
The drain plug was pretty goobered up with very fine particles.
Old Mar 7, 2010 | 02:34 PM
BLKBAGGER's Avatar
BLKBAGGER
One thing to keep in mind is you are seeing all the clutch disc wear in that oil. I change mine at 5,000 mi and also use dexron III ATF fluid.
Old Mar 7, 2010 | 02:36 PM
DPete's Avatar
DPete
Change mine @ 5K also 10K is to long IMO
Waterman1
Milwaukee Eight (M8)
13
Aug 30, 2017 11:19 AM
thevirginian
2014-2024 Touring Models
Jul 14, 2015 12:12 PM
HoldFast71
Oil Archive (no new posts)
Jul 27, 2012 07:32 PM
Robtarra39
Apr 25, 2011 06:58 PM
kelton3
Apr 28, 2008 06:12 PM
