torque wrench question
Old Mar 11, 2010 | 04:11 PM
Jags93's Avatar
Jags93
you simply won't have the resolution required for the smaller fasteners.
Old Mar 11, 2010 | 04:18 PM
05RK's Avatar
05RK
Originally Posted by clayharley
Ok, you might tell someone later today how dumb my question is and have a good laugh, but here I go. I've never used a torque wrench before so I went out and bought a 3/8th socket wrench and am about to go around my RK and tighten everything down, but the lowest setting on the wrench says 80 lb/inch. My question is in the Harley manual there are man bolts that require torque less than 80. Did I buy the wrong torque wrench and need a wrench that goes to lower settings? Sorry, I must sound like an idiot.
There are 2 different torque values...inch pounds and foot pounds. When you say a "torque less than 80" need to know if it is 80 inch pounds or foot pounds. One foot pound equals 12 inch pounds. So....80 inch pounds is the same as 6.7 foot pounds. Check your wrench and the values you are trying to set.
Old Mar 11, 2010 | 05:52 PM
n8dc's Avatar
n8dc
I took it as 80 inch pounds and ill bet im right .. they do make one that starts at 80 inch pounds ..
Old Mar 11, 2010 | 05:58 PM
atrain68's Avatar
atrain68
I have a Sears Craftsman in/lb and a Kobalt ft/lb torque wrenches. If I did it all over, I'd go with Kobalt on both. I really like their tools.
dabirds1's Avatar
dabirds1
Originally Posted by Badfinger
I was also taught to zero them out after use I'm currious if anyone else told to do that?
yes you want to turn them down to the lowest setting
Old Mar 11, 2010 | 08:08 PM
TN Houndog's Avatar
TN Houndog
Originally Posted by BLACK BAGGER
I got a in/lb 3/8 rachet torque wrench 0-250 in/lb at SEARS $69.00 craftsman .Who's got a convertion chart for inch/lbs vs ft/lbs IS THIER ONE .
12 in lbs= 1 ft lb
Old Mar 12, 2010 | 10:11 PM
Rain's Avatar
Rain
Has anyone tested one of the Harbor Freight inch pound torque wrenches for accuracy out of the box? I picked one up today and am not sure if I'll keep it or shell out the money for a better one.
Used to wrench on cars for a living and would not have dreamt of using a $20.00 torque wrench then but this one looks pretty good for $20.00 for home use. I have one of their $70.00 bike lifts and have had my FLHTC up on it a lot and it's great.
Old Mar 12, 2010 | 10:25 PM
CroK's Avatar
CroK
http://www.unitconversion.org/energy...onversion.html
Old Mar 12, 2010 | 10:38 PM
creep1's Avatar
creep1
All you roadglide owners out there- the outer fairing torque screws have a value of like 6-12 inch lbs. thats low. I got a torque screwdriver for that. I think its used in automotive applications like dashboards.
Old Mar 13, 2010 | 08:11 AM
Landon's Avatar
Landon
I work for a facility that completes calibrations of different tools. We had an operator bring in his new Harbor Freight torque wrench. It could not be calibrated even when new. I would be cautious of them.
