'98 Ultra rear shock max PSI
Old Jul 31, 2006 | 05:57 PM
gregl's Avatar
gregl
Stage II
Default '98 Ultra rear shock max PSI
I have a '98 Ultra and frequently bottom out on rough roads with 15 PSI in the rear shocks. Since this is my first Harley I wasn't sure what to expect - but I didn't expect to bottom out! I'm 6'4 245 lbs and my wife is 5'11 150 lbs...plus stuff in the bags and the total weight is well over 400 lbs.
Searching the forums I've seen anywhere from 10-15 PSI up to 25 PSI. What is the max PSI these shocks can handle? I also read somewhere that the rear suspension travel for an Ultra is only ~3 inches which isn't much. Are heavy duty shocks/springs available?
Thanks,
Greg
1998 Ultra
1985 K100 RT
1977 R00/7
Old Jul 31, 2006 | 07:56 PM
pittguy's Avatar
pittguy
Default RE: '98 Ultra rear shock max PSI
25 psi is too much.10 psi was once the max,your newer model may be alittle more.No more than 16 lbs.
Old Jul 31, 2006 | 08:16 PM
V2 Bagger's Avatar
V2 Bagger
Check out Heavy Duty Progressive 440's. I ditched my worn out air shocks for a set and it was well worth the money spent. Progressive 440's are non air coil over.
http://www.progressivesuspension.com/series_440.aspx
junior166745151
Air Suspensions
18
Sep 3, 2017 11:05 PM
Roadster
2014-2024 Touring Models
Sep 5, 2016 03:28 PM
Bigdad68
Oct 12, 2010 07:28 PM
Lcarr
Oct 19, 2009 02:06 PM
StreetGlider56
Apr 7, 2007 02:34 PM
