What else to do while front fairing is removed?
Old Aug 1, 2006 | 01:30 AM
bdjhog's Avatar
bdjhog
Default What else to do while front fairing is removed?
I purchased the HD front fork lowering kit and will be installing in the coming weeks. I figured while I have the front fairing removed I should probably take care of as much as I can now so as not to have to remove it again anytime soon. Some other plans are to replace stock handlebars with touring pullback bars, replace useless air temp guage with oil temp guage and upgrade to Hogtunes. What other mods require the front fairing to be removed? I may not necessarily be planning to do those things, but then again I might. Thanks.
Old Aug 1, 2006 | 01:46 AM
Rhubarb's Avatar
Rhubarb
Default RE: What else to do while front fairing is removed?
Put in a "FastTrack", EzPass, EzLink, or whatever they call them in your area for crossing toll bridges and roads.
Old Aug 1, 2006 | 01:50 AM
PipeDADDY's Avatar
PipeDADDY
I did...
In Dash Antenna
Hog Tunes
XM power converter
cabling and wiring
oil temp guage
Old Aug 1, 2006 | 02:03 AM
bdjhog's Avatar
bdjhog
Ahh..the hidden radio antenna. Forgot about that one.
Old Aug 1, 2006 | 03:16 AM
KY HDRider's Avatar
KY HDRider
I will modify my spots to remain ON even while high beam is on the next time my fairing is off. A close encounter with a deer last weekend sealed the deal on my decision. The more light, the better IMO.
See this page for info. How to make your passing lamps stay on when your brights are on
Later,
04ultra
Old Aug 1, 2006 | 03:17 AM
dgator66's Avatar
dgator66
Good time to get the painted inner fairing, too.
Old Aug 1, 2006 | 09:51 AM
bradteed's Avatar
bradteed
how about an air compressor? on-board air compressor
Old Aug 1, 2006 | 10:14 AM
Mr Wonderful's Avatar
Mr Wonderful
Don't know what year your bike is, but you can put the XM antennae in there. I've seen some SE bikes that simply put them on top of the radio itself.......factory did it. You could also relocate your ambient air temp sensor to outside the fairing.
Old Aug 1, 2006 | 12:10 PM
harley0711's Avatar
harley0711
Chrome the lowers
Old Aug 1, 2006 | 01:09 PM
billnourse's Avatar
billnourse
Here are my under fairing changes.
HogTunes, XM Radio antenna on radio case, Dakota Digital powered radio antenna, and aux. power point installed in the right side of the inner fairing.
Regards,
Bill
