My 88 5 speed 3 grand is running 75 mph............I would like to hear from someone who has an 88 with the SE 6 speed before I speed the $
I used to have a 98 wideglide with se 6 speed. It was great for traveling, and easier on the motor at freeway speeds. It did bring the rpms down as you expect it to. It's good if you want to spend the money and do much traveling to use it.
On my SG I still don't run 6 gear till over 70mph. I use 5th and run rpms about 26-2800 and thats well over the speed limit. But it sounds good right there. Any lower and I almost can't hear it, I have RH TD.
You can't compare rpm at speed between a twin and a 4 cyl. Apples and oranges as far as where the hp and torque show up in the rpm range. Bikes are geared differently for that reason.
I guess I'm still use to the 2200 RPM's at 70 on my Goldwing. 3,000 RPM's seems to be more than it should be at 70 but I think it may be the sound of the engine that's making it sound like the RPM's are to high. It feel like I've got to be doing at least 65 before cruising in 6th gear. Got to be careful in my neck of the woods. Our local LEO's like to write tickets.
Go ride a sport bike, you'll cruise at around 6000rpm.
Being retired and living near the mtn's, I very seldom ride the interstate.
When I'm in 6th gear and 70 mph, I'm turning 2500 rpm's. This is a good subject because I hear various opinion's on how fast you need to be to use 6th gear? What's everybody's opinion on this? I keep my rpm's above 2K in any gear. If I'm two up and start up a hill, I'll drop down a gear to get up to 2500. I might add, it has alot more throttle response and can use 6th gear at 60 mph better since upgrading the AF and Mufflers. JMO
Just curious, but do you still wear shorts and flip flops when riding your Harley, like you did when you rode your Goldwing? lol
Visit Edmond Oklahoma in the summer time (right on Rt 66) and you will see a lot of Harley riders in shorts and flip flops.
As for the 5 spd with the 88: it took a long time for me to get used to riding in lower RPMs on my 09 SG. It still doesn't feel quite right really. I rather enjoyed cruising on my 02 RKC at 80mph in the higher RPMs and I still got better mileage than SG. Personally I would stick with the 5 spd.
