Oil filter gunk
Old Mar 18, 2010 | 08:01 AM
keith t's Avatar
keith t
Default Oil filter gunk
Hi all
Here is the shortest story I can tell, I have an 09 Ultra with a 106 bottom end and stock heads and 12.5K miles. Changed fluids at 10K, mid December. A couple of weeks ago going down the highway, engine starts tapping and oil pressure starts to swing from 20-ish to 50-ish. Checked oil and surprise, hardly any. Went ahead and changed oil and filter, wish I had kept filter to open up for evidence of bad news, but didn't find anything on the drain plug. May have slid by on that one, still runs strong but has picked up a little ping on acceleration, no idea how it happened, but air cleaner (Stage 1) shows oil in the 9:00 area.
Wonder if oil pump may be to blame? I hear the stock pump may not scavenge as well as it could, and considering upgrade pump. Any advice out there?
Thanks
Firedog -Tulsa OK
09 Ultra Classic Electra Glide 106/251 cams/ SEPT/ V&H Monster/lots of bolt on stuff
Old Mar 18, 2010 | 08:49 AM
Iron Aces's Avatar
Iron Aces
I've got a friend that has the upgraded '09 Screamin' Eagle motor on his Road Glide and was having a similar problem, in addition, he was losing oil but couldn't find a leak anywhere. Come to find out, they had a recall on the motor and they replaced it, free of charge.
Also, this doesn't really solve the problem but could help in finding out if there are indeed shavings in the filter that would point to a larger problem....have you considered getting an oil filter that has a magnet to collect shavings? I've also seen out there a ring-type contraption that screws onto the bottom of the filter that is then screwed onto the motor that is contains a magnet. This will work on any standard filter if you didn't want to purchase a more expensive, special filter. Just a thought.
Good luck finding the problem....
Lindsey :0)
Old Mar 18, 2010 | 11:03 AM
keith t's Avatar
keith t
I certainly plan to check the filter at the next change, and will check on the magnet idea, thanks. Hmmmm, recalled the motor? Wonder if theat was based on the oil pump. Guess i should check that out too
kt
Firedog -Tulsa OK
DK Custom Products
Vendor For Sale Classifieds
17
Aug 31, 2023 01:51 PM
DK Custom - ST
13
Aug 18, 2023 10:45 AM
Leebert1
Dec 8, 2013 02:25 PM
Jsans
Oil Archive (no new posts)
17
Oct 20, 2007 09:15 AM
Wolf
Sep 6, 2005 11:03 PM
